top speed with 4.10's?
Old Feb 21, 2011 | 01:50 PM
mcm95403's Avatar
mcm95403
Default top speed with 4.10's?
The Daytona thread in the general section wound around to my comment about the potential to use 6th gear with 4.10's and the question that goes with that is what top speed could a coupe really hit with that combo? I say coupe only because the FRC/Z06 roof line isn't as aerodynamic as the coupe.
So, does anyone here have real numbers on top speed in 6th with 4.10's? From my speed spread sheet it looks like 6000 rpm in 5th with 4.10's would be about 153 or so - I'm wondering if the extra gearing of the 4.10's would put the engine into a range where it could pull in 6th rather than slow down like has been reported with shifting into 6th with 3.42's.
Old Feb 21, 2011 | 02:02 PM
dougbfresh's Avatar
dougbfresh
Does it really matter-when was the last time you did 153?
Old Feb 21, 2011 | 03:06 PM
Old Horsepower's Avatar
Old Horsepower
Last week!
Old Feb 21, 2011 | 03:29 PM
dougbfresh's Avatar
dougbfresh
Who put's on 4:10's and worries about top speed anyway-they are for out of the hole acceleration-not top speed.
Old Feb 21, 2011 | 03:30 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
I hit 157mph bumping the rev limiter on 5th
Old Feb 21, 2011 | 03:31 PM
AU N EGL's Avatar
AU N EGL
That is why we use 3.42s
6700 Red line 4th gear, is 155-157 mph depending in tire air pressure. Shifting to 5th ( with a 1500 rpm drop to 5200 rpms) is 161 - 163
6th gear in the corvette is a highway gas milage gear not a performance gear.
Only the ZR1 gear ( GM Motorsports ratio) ratio is a performance gear.
4.10s are for acceleration, not top end.
Old Feb 22, 2011 | 08:56 AM
wca_tim's Avatar
wca_tim
I run 4.10s...
...and top speed is definately faster than I need to go on any public road...
That's one of those traffic stops where you probably leave in the squad car...
Old Feb 22, 2011 | 09:56 AM
rkboz's Avatar
rkboz
I don't have an answer but I do have an opinion. There is nothing wrong with your question. These cars are a hobby and asking hypothetical questions are part of that hobby. I for one also want to know if 6th gear will pull with 4:10s at high speed......just curious.
Old Feb 22, 2011 | 10:04 AM
Cardinal Flyer's Avatar
Cardinal Flyer
Old Feb 22, 2011 | 10:18 AM
mcm95403's Avatar
mcm95403
Thanks for the feedback guys! The questions wasn't about doing anything stupid on the street, it was about running on a track like Daytona or Talledega and the possibility of getting more top speed out of a mildly modded LS1 coupe by giving it better gearing to work with.
I realize 6th is only there for mileage and it does a great job at that. The question still stands though so maybe someone who has 4.10's will chime in with an answer.
Old Feb 22, 2011 | 06:51 PM
lionelhutz's Avatar
lionelhutz
You have a spreadsheet already? Where does rpm's in 6th gear with the 4.10 gears land compared to the old gears? Compare 6th with 4.10 gears vs 5th with 3.42 gears and see where in the power band you are with each combo. If you put the engine at a rpm where the hp is higher then it will be able to accelerate thecar to a higher speed. Figuring out how much more speed is the hard part. Well on paper it's tricky but if you drive it you'll find out.
Peter
Old Feb 22, 2011 | 08:41 PM
dougbfresh's Avatar
dougbfresh
Do you have a 4:10 rear end? Do you plan on driving Daytona or Talledega with your car??
Old Feb 22, 2011 | 08:52 PM
RobWilson's Avatar
RobWilson
I have seen the top of 5th gear with my 4.10s, which is 172 mph at 6700 rpms. This was in a one mile shootout as part of the Sandhills Open Road Race, last August. I haven't had an opportunity to try and pull 6th gear at that speed. I don't think I've ever been over 100 mph in 6th gear.
Old Feb 22, 2011 | 08:55 PM
mcm95403's Avatar
mcm95403
Awesome, thanks for the info!
Old Feb 22, 2011 | 10:47 PM
wcdaniel's Avatar
wcdaniel
Just for documentation purposes, in controlled conditions, I took my 2003 C5 Coupe mn6 all the way to 170 in 5th gear and it was just getting into the red stuff on the tach and I shifted to 6th and it acted like it bogged down. So I shoved it back into 5th and ran it up to 177. That was plenty for me.
But as the OP stated, what reargears would be necessary to allow 6th to "pull" at those speeds. I read the comments about spreading it out on a spreadsheet. However, I believe the OP wanted to hear from someone as crazy as us that actually went out and did it with the specific intent of getting 6th gear efficiently involved in the pull.
Who knows, no one may have been as crazy as we are !!!!
Old Feb 22, 2011 | 11:22 PM
lionelhutz's Avatar
lionelhutz
I know the proof is in the testing but the first step is to look at the gear ratios and the engine power. If you drop the engine to a lower HP you won't pull a higher speed. There is no if, and or but maybe here. If the engine does not produce more HP in 6th gear then the car won't go faster. The top speed of a C5 coupe is around 173mph. So, check the HP of a stock car at that speed and then check again using the 6th gear ratio and your new rear gear ratio. The HP change will tell you if it's a winning or losing combination.
Peter
Old Feb 22, 2011 | 11:34 PM
cruisemon's Avatar
cruisemon
I had only had my '98 a few weeks and in a controlled environment found that the car really struggled in 6th starting around 143-144. Didn't know/think about dropping back into 5th to get back in the fat part of the torque curve. I really think the 4.10 might be enough to get far enough into the torque curve so that top end might not be that much different from the 3.42. I want to remember that 5th is a .75 overdrive and 6th is a .5 overdrive.
Charlie
To top speed with 4.10's?
Old Feb 22, 2011 | 11:48 PM
wcdaniel's Avatar
wcdaniel
Charlie
Thanks for the input.When I did it, I hit 170 and shifted to 6th and it slowed down. So I shoved it back into 5th and let it wind out to 177 which was about 6,300 rpm which did not make me very comfortable so I let off and allowed it to roll out. Try it, start out at maybe 90 and leave it in 5th all the way up. It is amazing how 5th can literally take us from about 15mph up to max speed. It is hard for me to get my arms around that idea but it actually works. But I still want to speak to someone that actually did it to find out for sure if the reargear can be situated where it won't bog out and will continue pulling.
Old Feb 22, 2011 | 11:50 PM
wcdaniel's Avatar
wcdaniel
Peter
Thanks for your input also. As you stated the issue is getting 6th into the far part of the torque curve where the horsepower can override the pushing of the air to effectively increase the speed. Right now with my '03 mn6 pushing about 400 hp, when I shifted to 6th at 170, it simply "hit the wall". The rpm was just not high enough to sustain acceleration, hence our questions. thanks again.
Old Feb 23, 2011 | 12:59 AM
mcm95403's Avatar
mcm95403
I just tried to post my spread sheet info, but it didn't work.
I'll upload it here: http://www.marcmedina.com/c5/gears.xls
Looks like with 4.10's and shifting at 6000 drops the rpm to about 4000-4100 rpm.
