Morel Lifters?
Old Feb 22, 2011 | 06:46 AM
C5Sweden's Avatar
C5Sweden
Default Morel Lifters?
Hello gents
I am seriously thinking of buying a set of Morel lifters for my LS7 but I am not really sure which one to go for, I am thinking of:
1) 184-4708-HYD, Morel Hydraulic Roller Lifter Set, LS1, LS6, LS2, LS3, LS7 and SBC Applications
or
2) 184-5206-HYD Morel Hydraulic Link-bar Roller Lifter Set, LS1, LS6, LS2, LS3, LS7 and SBC Applications
IF I would go ith the one with the link-bar, could I then remove the stock plastic holders for the lifters? Any pro or cons for that?
What is the actual difference between these two set of lifters and which one to go for?
Thanx for input
Best Regards
Tommy
Old Feb 22, 2011 | 07:07 AM
Blorton's Avatar
Blorton
Yes, if you use the link bar lifters, you get rid of the trays.
Morel makes awesome lifters. You really can't go wrong with either one.
Old Feb 23, 2011 | 03:54 AM
C5Sweden's Avatar
C5Sweden
Would like feedback from someone who have been using them!
Thanx
Tommy
Old Feb 27, 2011 | 08:52 PM
Evilknievel1028's Avatar
Evilknievel1028
1st Gear
got morels in mine. link bar, great quality, no noise. Well minimal noise. What I would call "normal cammed with headers noise." Heard some things about Comp R lifters, but after a friend lost his motor to turning one and losing the needles, I'm glad I got the morels. Can't say too much, just I'm happy with them. IMO either ones would be a good choice, link bar would prevent the described catastrophe though.
Old Feb 27, 2011 | 11:10 PM
heavymetals's Avatar
heavymetals
No link bar, but they work great.
Old Feb 28, 2011 | 06:16 AM
vettenuts's Avatar
vettenuts
I am running Morels as well, but unsure of the part number. They are much better quality then anything else available. Two things to note, first they are taller then stock and require a different preload (0.030"-0.050") so that pushrod length will be shorter then if equivalent GM lifters are used. Don't pre-buy your pushrods, make a final measurement once the motor is assembled and then order pushrods.
Old Feb 28, 2011 | 09:58 AM
WKMCD's Avatar
WKMCD
When I replaced my Caddy Racing lifters with the link-bars, I needed pushrods that were about .050 shorter. That being said, it's ALWAYS best to measure. Measure both intake and exhaust.
Old Feb 28, 2011 | 11:16 PM
paint it black vette's Avatar
morels and i have no morals
Old Mar 1, 2011 | 03:39 AM
99blancoss's Avatar
099blancoss
Former Vendor
St. Jude Donor '10-'11-'12
Here you go
http://www.mcssl.com/store/cc-perfor...59fad3a420bc85
5206 is the part number, we've been using/offering them for a few years now
To Morel Lifters?
