what compound to use?
Old Feb 24, 2011 | 09:01 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default what compound to use?
On a trip to California, my 01 MN6 coupe got smacked with a tire tread ejected off of a semi in a rain storm.
What compounds are there to repair the SMC?
I have a small gouge, and at the primary point of impact, the fibers are exposed on the fender and the rocker panel where the door meets them.
Old Feb 24, 2011 | 10:21 AM
dougbfresh's Avatar
dougbfresh
Spot putty will work fine.
Old Feb 24, 2011 | 11:24 PM
coupeguy2001
I will have to dig out all the fractured material in order to do a repair. I need more than spot putty.
Old Feb 24, 2011 | 11:33 PM
Tech's Avatar
Tech
Spot putty? lol
Can you take a picture?
Old Feb 25, 2011 | 12:03 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
May try some dynaglass or fiberglass reinforced body filler like that.
Old Feb 25, 2011 | 06:43 AM
dougbfresh's Avatar
dougbfresh
If it's just a small gouge spot putty will work fine, the 2 part kind that won't shrink.
Old Feb 26, 2011 | 04:41 PM
GM Fan's Avatar
GM Fan
This Vette Magazine article (mainly on page 2-3) I saw yesterday covers using "Plastex" to repair a cracked fender: http://www.vetteweb.com/tech/vemp_11...air/index.html
Might work for what you need, can't speak from experience though.
Old Feb 27, 2011 | 12:03 AM
coupeguy2001
it is more than a small gouge. it is a splintering of the surface about 3/4 of the way through the material.
In addition to the splintering, there is a small gouge about 2 inches away from the initial impact. That is where the spot putty might work just fine.
Old Feb 27, 2011 | 03:01 PM
Daffy's Avatar
Daffy
Florida turtle advocate
St. Jude Donor '05-'06
Duraglass filler after grinding away the loose stuff. then something like an evercoat glaze filler to finish it off.
Old Feb 27, 2011 | 05:54 PM
coupeguy2001
thanks guys
Old Feb 28, 2011 | 03:33 PM
kh400's Avatar
kh400
I have used, with great success, permatex Permapoxy. Part number 84115. You can get it at advance auto parts. Walmart also sells it under a different brand name. It is a two part epoxy and works well, is sandable and can be used with glass cloth or without. Hope this helps. Good luck!!!!
To what compound to use?
