c6 z06 shock install problem
Old Feb 25, 2011 | 02:11 PM
bags142's Avatar
bags142
Default c6 z06 shock install problem
I am in the process of changing my shocks to the c6 z06 shocks. The front passenger side went in no issue. The drivers side is where I am having my problem
The front drivers side c6 z06 shock is fouling/chaffing the upper control arm. It's the upper plastic shroud on the shock that is touching the upper control arm. No matter what I do, it seems that I can't get it to not touch the arm.
Search did not turn up anything
TIA
good call lucky.. pic for refference... lower right side of the shock in pic
Old Feb 25, 2011 | 02:19 PM
lucky131969's Avatar
lucky131969
TIA
Perhaps you can post a pic......shocks are about as straight forward as it gets.
Old Feb 25, 2011 | 02:34 PM
bags142's Avatar
bags142
true and done... and that is why i am so confused wtf is wrong
Old Feb 25, 2011 | 02:42 PM
lucky131969
And what happens when you compress the spring i.e. simulate a normal suspension position, as if the car was on all four wheels?
Old Feb 25, 2011 | 02:44 PM
bumble-z's Avatar
bumble-z
Have the top of the shock push back into the cyl & tied off w/a couple of zip ties?.
Have the lower arm pushed up a bit?
Get it in postion & bolt up.
Old Feb 25, 2011 | 02:55 PM
bags142's Avatar
bags142
as it compresses/goes up, the cotrol arm moves up and off the shock... but the old ones did not do this.. that what is confusing
it is bolted in and I used that method.. and this is the result
Old Feb 25, 2011 | 02:57 PM
lucky131969
I don't have c6 shocks, but I'm quite certain, that your old shocks are a smaller diameter, and so is the shroud.
Old Feb 25, 2011 | 03:32 PM
bumble-z's Avatar
bumble-z
If your all buttoned up, looks if you were to put the weight on the lower arm as when the car is on the ground, there will be clearance.
Old Feb 25, 2011 | 04:08 PM
Cardinal Flyer's Avatar
Cardinal Flyer
However, while there is much less space, I did not have contact when I installed mine. I did have a VERY difficult time getting the front shocks in the proper position to secure the bottom bolts. I secured the top first and kept playing with the bottom until I had clearance.
Old Feb 25, 2011 | 07:01 PM
bags142's Avatar
bags142
I think you are correct, but I can't be the only person with this problem if it is an issue. I am worried I may have a bad upper control arm bushin or something
You are correct. But, does that mean this is ok?
I am planning on taking the shock back out and trying again.. just to see if that helps
Old Feb 25, 2011 | 09:16 PM
lionelhutz's Avatar
lionelhutz
Don't worry about it. One of mine touches like that too. It's no big deal since it only touches when the suspension is hanging.
Peter
Old Feb 25, 2011 | 11:36 PM
rebelheart's Avatar
rebelheart
If it only touches when the suspension is hanging it is a non issue!
Old Feb 26, 2011 | 11:02 AM
lucky131969
It's not a tumor. If you can't understand, that the suspension hanging freely, is different than when the car is on all four tires.....I don't know what to tell you.
Old Feb 26, 2011 | 11:14 AM
bags142's Avatar
bags142
I get that the only time the suspension is like this is when on jacks or pulling a duke's of hazard jump.
What I was saying was, If this happens on occasion, I expected to see threads where people may have asked or reported it. And I know a decent bit about cars, but what I know more than anything is if I change a part and the new part creates a situation that was different than before, I just don't ignore it. And while I may worry to much about it, when I am doing an HPDE and I am going ~130 mph, I want to know that my ride is right.
That's why I was asking. For example, if with the old shock installed, a bushing was worn out but held in place and everything looked fine. Now after removing the shock the bushing is out of whack and causing the new shock to not be installed correctly. Thus I have a bad bushing.
But, it seems I was over thinking and overreacting.. nothing new there!!
But thanks for the replies and letting me know I am not the only one with this as an issue.
Old Feb 26, 2011 | 07:10 PM
craig04c5's Avatar
craig04c5
When I did mine one of the stock shocks left the bushing behind and up on the top of the bushing mount and I did not notice it until I installed it and lowered the a arm down. Check you old shocks to make sure both bushings came out with the old shocks.
To c6 z06 shock install problem
