Need Help checking Continuity of...
Feb 28, 2011 | 02:22 PM
Spark plug wires. i have a Multemeter i bought about a year ago but have no idea how to use it
heres what i have,
Feb 28, 2011 | 02:30 PM
Specifically, you are measuring resistance, not just check continuity.
Connections:
Red lead = V , Ohm, mA, Temp
Black= COM
Set the dial to the lowest resistance value = 200 Ohms (symbol omega)
Record the digital reading.
Feb 28, 2011 | 02:51 PM
Feb 28, 2011 | 03:10 PM
Quote:
Originally Posted by
lucky131969
Connections:
Black= COM
Sorry, wires measure , as a rule of thumb five thousand ohms per foot, so I would put the meter at least at 20K ohms. Good luck!!!!
Feb 28, 2011 | 03:17 PM
kh400
Sorry, wires measure , as a rule of thumb five thousand ohms per foot , so I would put the meter at least at 20K ohms. Good luck!!!!
Try again. What wire were you measuring barb-wire?
I would believe something more along the lines of .2 ohms (2 milli-ohms) /ft.
Feb 28, 2011 | 03:47 PM
kh400
Feb 28, 2011 | 04:18 PM
thanks lucky
i tried it at 200Ω but wasnt getting a proper reading. it was showing "1--.-"
moved it to 2kΩ and got these readings
0.362
0.371
0.377
0.367
0.359
0.371
0.370
0.365
so are my plugs good?
lucky131969
Connections:
Black= COM
Feb 28, 2011 | 04:29 PM
Last NAPA wires I bought Ohm'ed out at about 100 Ohms each. The stockers I took off were in the 500 Ohm range.
Feb 28, 2011 | 04:44 PM
mickey_7106
thanks lucky
0.362
0.371
0.377
0.367
0.359
0.371
0.370
0.365
I can't speak to the plugs, but the wires are good.
Feb 28, 2011 | 04:49 PM
mickey_7106
thanks lucky
0.362
0.371
0.377
0.367
0.359
0.371
0.370
0.365
Not according to the post with the manual page-you multiply the number you get by 2000 (the 2K scale) and all of your wires are above 700 Ohms.
Feb 28, 2011 | 05:40 PM
dougbfresh
On this particular meter, the resistance numbers(on the selector dial) are the range, not a multiplier. His wires are ~360 ohms, which is why the meter read a "1", on the 200 ohm scale. So the next scale reads up to 2000 ohms, which will give a reading in kilo-ohms. .360 x 1000 = 360 ohms.
