Brake lights not working
Old Mar 1, 2011 | 02:06 PM
Leviner's Avatar
Leviner
8th Gear
Default Brake lights not working
Need advice on how to repair brake lights w/o having dealer charge me $500.+ for changing a switch. Has anyone had this happen with their 2002?
Old Mar 1, 2011 | 02:09 PM
lucky131969's Avatar
lucky131969
You have isolated the problem to the stop lamp switch?
Old Mar 1, 2011 | 02:11 PM
Justin-Sane's Avatar
Justin-Sane
If its the Multi Switch your speaking of, you can fix it yourself for free. pretty simple really.
here's how.
Removal:
http://forums.corvetteforum.com/c5-t...-a-how-to.html
Switch Repair:
http://forums.corvetteforum.com/c5-t...f-replace.html
Old Mar 1, 2011 | 02:41 PM
Leviner's Avatar
Leviner
8th Gear
Yes, do you know an easy way to replace?
Old Mar 1, 2011 | 02:42 PM
Leviner's Avatar
Leviner
8th Gear
Thanks for the advice. I will give it a try.
Old Mar 1, 2011 | 02:43 PM
lucky131969
Yes to what?? Stop light switch or MFS?
Old Mar 1, 2011 | 02:50 PM
Leviner's Avatar
Leviner
8th Gear
Will have to do a little more trouble shooting and get back to you. Thanks
Old Mar 1, 2011 | 03:32 PM
Chicago1's Avatar
Chicago1
Ummm before you start doing that take the passenger side floor panel out and see if you have a blown fuse.
Old Mar 1, 2011 | 07:01 PM
Leviner's Avatar
Leviner
8th Gear
Is the MFS the same as the Hazard Flasher? Just had shop confirm it needs replacing and I hope to do it myself and save $500+
Old Mar 1, 2011 | 07:50 PM
lucky131969
No it's not.
Old Mar 1, 2011 | 07:52 PM
Leviner's Avatar
Leviner
8th Gear
Thank you for your advice. It looks like I can get to the flasher throuh the radio and save the money.
Old Mar 2, 2011 | 08:51 PM
Leviner's Avatar
Leviner
8th Gear
Default Fantastic resource!
I used the step by step process and replaced the flasher switch which fixed the tail lights. Thanks to all who offered advice.
To Brake lights not working
