po4o1 help!!!!
Old Apr 13, 2002 | 05:39 PM
timothy's Avatar
timothy
Default po4o1 help!!!!
the dealer can't figure out why im throwing this code they changed some vacum lines with no luck. i want this check engine light gone please help
thanks in advance :cry
Old Apr 14, 2002 | 08:01 PM
hog's Avatar
hog
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Contributor
Default Re: po4o1 help!!!! (timothy)
There is no p0401, do you mean p0410?
Old Apr 14, 2002 | 11:04 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
The P0410 code is commonly caused by damaged vaccum lines under the battery due to battery acid.Without vaccum to the air pump control valve,the air pump wont deliver air to the exhaust manifolds,resulting in the P0410 code.You need to check for vaccum at the control valve while the air pump solenoid is commanded on with a TECH2...
To po4o1 help!!!!
