output shaft
Old Mar 2, 2011 | 10:30 PM
pat750r's Avatar
pat750r
Default output shaft
Can you replace the pasenger side output shaft without removing the differential from the car? If so does anyone have any diy directions.
Old Mar 2, 2011 | 11:05 PM
bumble-z's Avatar
bumble-z
Differential needs to come out.
Old Mar 2, 2011 | 11:44 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Heres all the info that you ever wanted to know about rearend internals, up-grading and reassembly:
- C5, Its Go Time, Output Shaft Install - Left and Right : http://forums.corvetteforum.com/c5-t...post1573404441
- C5 RAGTOPWS6, Differential UP-Grade; http://forums.corvetteforum.com/c5-g...-z06-guts.html
Old Mar 3, 2011 | 08:01 AM
pat750r's Avatar
pat750r
Even if i'm just removing the right side??
Old Mar 3, 2011 | 01:04 PM
ragtopws6's Avatar
ragtopws6
It cannot be done. The pass side cover can be removed but there is a metal block (one of the stud is threaded to this block) inside the main housing and the carrier with the output shafts cannot be removed without first removing this block. The diff has to be removed from the trans and the 2 7mm bolts removed in order to take the block out.
Old Mar 3, 2011 | 01:30 PM
pat750r's Avatar
pat750r
Ok thanks for your help guys..! One more question is can I change
That one spider gear only without having to worry about the shims,bearing, gear backslash ect ect ??
To output shaft
