Front Main Engine Cover Gasket replacement instructions?
Old Mar 3, 2011 | 05:36 PM
BigGoals's Avatar
BigGoals
Default Front Main Engine Cover Gasket replacement instructions?
Does anyone know of a write up for replacing the front main engine cover gasket? My manual doesn't give me enough instruction on what needs to come off and what needs to be replaced in the process.
Old Mar 3, 2011 | 06:11 PM
sfc rick's Avatar
sfc rick
Go to LS1howto.com and click the cam swap instructions. You'll do everything up to removing the timing cover and then you are done,
