Reverse Grinding
Old Mar 4, 2011 | 08:08 PM
Seraphus's Avatar
Seraphus
Default Reverse Grinding
Hey all,
First off, i wanted to thank lucky for helping me with my P0410 code.
Second, I only have one more issue with my newley purchased C5Z.
Some infor on the car:
2002 C5 Z06
13,450 miles
Only mods = KN Intake, lowered.
As the title states when i throw the car into reverse to, say, paralel park, it will interminently "pop out" of reverse and grind the gear. I don't have the issue if I use some force to throw it in and let the clutch out SLLOWWWWLY but I don't think this is normal. I did some searching and found various things that could be wrong with it but most examples where high mileage vehicles.
I swapped the clutch fluid yesterday (it was black with crap in it, swapped 4 cans and it's now clear). The clutch seems smoother and more cooperative now but when i tested reverse about an hour ago it still popped out unless i had my hand on it.
Can the forks be bent/damaged on such a low mileage car?
Thanks for your help guys!!!
Old Mar 4, 2011 | 10:05 PM
sfc rick's Avatar
sfc rick
The shifting fork has a piece of plastic on each of the "legs". It's a common problem for the fork to lose one of the pieces and then when you try to shift into reverse the gear can't be fully engaged. The fork is too thin when the plastic breaks off and there is lot's of slop in the collar it rides in.
BUT!
It could also be sloppy shift linkage from the shifter to the transmission, just pull up the boot and look at the 6mm bolts that hold down the shift plate to see if it's lose.
Other than that I don't have a clue.
I just had a transmission rebuilt cause my reverse kept popping out and I saw the shift fork plastic broken off.
No miles on the car BUT it's still 10+ year of old plastic.
Edited to add I designed gear boxes for Lufkin Industries for awhile(Google it) and I couldn't believe how cheap GM was by using plastic tips on forks..... Lufkin would never stand for that kind of gear box.
edited to add a little bragging about Lufkin building some VERY high speed gear boxes, not many in the world compare to a Lufkin gear box. Our gear boxes can do 60,000RPM's and the teeth of a gear can travel 180miles PER SECOND! http://www.lufkin-france.com/eng/test_bench.html
Old Mar 5, 2011 | 04:53 AM
xSeraphusx's Avatar
xSeraphusx
That's a good point on the plastic being 10 years old. How big of a deal would it be to replace those?
I'll pull the boot up tomorrow and check those screws.
Thanks!
Old Mar 5, 2011 | 07:54 AM
64camo's Avatar
64camo
8th Gear
Mine will do the sae thing sometimes. I have foundd that if I shift from 6 to rev it is better. I think it is a flaw in the transmission linkage. I can tell by the feel when itis going to do it and I then just shift into 6 and back to reverse and its ok.
Old Mar 5, 2011 | 09:00 AM
helga203's Avatar
helga203
Originally Posted by Seraphus
Hey all,
2002 C5 Z06
13,450 miles
I have 99 with 90k this is a flaw in gm i checked with gm this is common if i don't hold in rev it pops out seems better when warm.I tried to aline shifter till i was blue in the face without luck.It sucks but how offen are you in reverse.Good luck
Old Mar 5, 2011 | 10:19 AM
ragtopws6's Avatar
ragtopws6
BUT!
I couldn't have said it any better. To the OP, the shift fork rarely bends, I have seem them break through.
Old Mar 5, 2011 | 10:24 AM
helga203's Avatar
helga203
Just wondering where do the broken pieces go this might bbe my problem,but wouldn't broken pieces damage other parts?
Old Mar 5, 2011 | 10:35 AM
ragtopws6's Avatar
ragtopws6
That is just luck of the draw. I have seen a case with a hole in it because one of the failed bearing got jammed between the gear and the case and the case lost. Most of the time, it just sits on the bottom of the transmission or captured by the magnets.
Old Mar 5, 2011 | 10:40 AM
helga203's Avatar
helga203
To Reverse Grinding
