a4 shifting on nitrous?
Old Mar 5, 2011 | 11:43 AM
01C5VETTEMAN's Avatar
01C5VETTEMAN
Default a4 shifting on nitrous?
Hey guys ,will an a4 trans shift out on a dry kit ...or will it bump rev limiter?? or do i need window switch for it to shift correctly? thanks
Old Mar 5, 2011 | 03:46 PM
01C5VETTEMAN
Bump for help....
Old Mar 5, 2011 | 03:51 PM
chassed's Avatar
chassed
id try LS1tech..this forum doesnt seem very helpful when it comes to tech info...
Old Mar 5, 2011 | 04:27 PM
imavettegirl's Avatar
imavettegirl
that does not sound right.
Old Mar 6, 2011 | 07:22 AM
99 vett babycar's Avatar
99 vett babycar
Originally Posted by chassed
id try LS1tech.....
Old Mar 6, 2011 | 09:10 AM
Sea Five's Avatar
Sea Five
ill help you out man.
you will spray through shifts with the nitrous active. this is not good for the trans, and also interferes with torque management, hurting performance if its not disabled already.
you will want a window switch and set the shut off rpm lower than your actual trans shift point.
its NEVER ok to hit the limiter on nitrous reguardless, so even a mistake could cost you.
i reccomend the nitrous outlet dual digital window switch. easy to install, and works perfectly, every time.
-Jeremy
Old Mar 6, 2011 | 11:59 AM
imavettegirl
see, someone knew the answer here.
Old Mar 6, 2011 | 12:59 PM
rebelheart's Avatar
rebelheart
I am willing to bet that Chuck Cow could write you a custom tune to address all those problems.
Old Mar 7, 2011 | 11:21 PM
Chuck CoW's Avatar
0Chuck CoW
Former Vendor
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
Default Yes but......
Yes but......I also agree with Sea Five. Don't play games with NyTrous.
No many 4L60e's are gonna live with NyTrous on the shifts at WOT.
#1 The car may not shift at WOT and if it doesn't, It will hit the limiter and hurt your motor.
#2 The trans can't take that beating if you've got good tires...Stuff will break.
A good safety system is worth it's weight in gold on ANY N2O install....
Chuck CoW
To a4 shifting on nitrous?
