chips88
Old Mar 8, 2011 | 10:54 AM
chips88's Avatar
chips88
Default chips88
air conditioner problem whenusing driverside air control i get no cold air just heat put in shop could not find and leaks, air works intermittingly
Old Mar 8, 2011 | 12:17 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Read and post your DTCs using the DIC. What is the status of the R-134 charge???
BC
Old Mar 8, 2011 | 12:30 PM
BRTC5's Avatar
BRTC5
I had this problem. Has to do with the vent control getting stuck or something... the fix was to disconnect the battery, wait 15 seconds, reconnect. I had to do it 3 times but eventually, with the power disconnected, the system resets itself. Of course if the control arm on the vent is broken this method won't work. Worth a try at least before you tear the dash appart. Also, use the search on the forum. There is a detailed fix is this doesn't work for you.
Old Mar 8, 2011 | 01:45 PM
chips88's Avatar
chips88
Tanks for the advice i will trythis first thanks again bd
chips 88
To chips88
