99 C5 Battery draining!
Old Mar 10, 2011 | 07:11 PM
wingnutphil's Avatar
wingnutphil
Default 99 C5 Battery draining!
I have a 99 C5 that is pretty much stock (with the After market radio). In the last month the battery started dying. I had the charging system checked (Alt charges between 13.8-14.1) and replaced the battery. It dies after the car sits for 1 1/2 - 2 days. I had the radio installed 3 years ago and everything seams to be working fine.
I logged the following DTC codes. Any Ideas?
28 TCS
C1255 H
A0LDCM
B2252 H
B2282 H
B2284 H
B2276 H
U1255 H
U1064 H
U1016 H
U1096 H
A1RDCM
B2283 H
B2285 H
B2277 H
U1064 H
A6SCM
B0851 H
B0856 H
B0RFA
U1255 H
U1096 H
U1064 H
U1016 H
Old Mar 10, 2011 | 07:24 PM
lucky131969's Avatar
lucky131969
http://forums.corvetteforum.com/1567522286-post590.html
Old Mar 11, 2011 | 07:53 AM
99 vett babycar's Avatar
99 vett babycar
all your codes are History codes, not current, so that isn't telling you anything. Make sure the battery is fully charged, then check your
"sleeping"( steady state) current draw as outlned in the above referenced post. If you have excessive current draw, then you can start pullinjg fuses to isolate the shorted circuit.
Old Mar 12, 2011 | 10:33 AM
wingnutphil
I found the fuse that is causing the problem. Fuse #4 under the passenger side. Not sure what circuit is fed thru the fuse. It says "SCM-L". Any ideas?
Old Mar 12, 2011 | 10:42 AM
lucky131969
Originally Posted by wingnutphil
I found the fuse that is causing the problem. Fuse #2 under the passenger side. Not sure what circuit is fed thru the fuse. It says "Monitored LD". Any ideas?
http://forums.corvetteforum.com/c5-t...ng-a-fuse.html
Old Mar 12, 2011 | 05:19 PM
wingnutphil
I listed the wrong fuse in the 1st post. It was actually Fuse #4.
Old Mar 13, 2011 | 09:12 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
It appears the SCM itself has issues. That fuse powers the SCM. I would be taking the seat out and examining all the wiring under there for shorted wires.
Old Mar 13, 2011 | 01:28 PM
wingnutphil
Thanks for the help and the diagram.
To 99 C5 Battery draining!
