So the little beeper or whatever that beep when you have your door open or it also sounds when your pressing different buttons to reset the dic and what not. It starting to sound muffled and really quiet almost like its dieing, does this happen or could this be something else? My battery is 100% good. Thanks in advance!
Pulled the codes only code is TCS, Sometimes it sounds normal then quiet and muffled. Where is the sound coming from maybe I need to smack it around a little bit
Your one of 5-6 people that experience this issue. It deals with the speaker driver amp inside the IPC.
UNFORTUNITLY,,, no one has any schematics for the inside of the IPC and figuring out what component the amp / driver is going to be tough. Short of swapping out the board, or disconnecting the speaker, i don’t know what to tell you.
BC
Yeh....Sounds like my luck. Sounds like a peice of **** now when I have the door open.. DAMN. Thanks for the help!!
