Melling oil pump help
Old Mar 10, 2011 | 11:46 PM
MyEBc5Z's Avatar
MyEBc5Z
Default Melling oil pump help
Ok I'm trying to install my Melling high volume oil pump but there are 2 different sized o rings for the pickup tube and I tried both but neither fit flush, I'm afraid to push on them too hard because of all the print problems please help
Old Mar 11, 2011 | 12:17 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The GREEN O ring is the one that you want to use. Oil it up, install it on the pick up tube and allow it to slip in the pump. Heres an example of how the O ring fits in the pump:
If the pick up tube flange fits FLAT on the pump flange and NO O ring material is being extruded, your fine.
BC
Old Mar 11, 2011 | 01:18 AM
MyEBc5Z's Avatar
MyEBc5Z
Bill Curlee you are the f****** man! Thanks
Old Mar 11, 2011 | 02:58 AM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Old Apr 1, 2012 | 06:56 PM
jjcrow's Avatar
jjcrow
1st Gear
Bill your my hero. I've been fighting to get the pickup tube to sit flush with the pump housing and it keep kicking out at an angle once I torque the screw down. Having a better understanding how how things mesh together your photo is invaluable!
Old Apr 2, 2012 | 10:28 AM
RonSSNova's Avatar
RonSSNova
The green O-ring is larger (thicker) than the stock one.
From the info I found over on the LS site, the green one is for trucks.
Of course I just finished mine up, installed the balancer and now I read this.
I will say that the assembly with the black O-ring hardly fell together. It felt correct to me.
I wish I would have taken the blue pill.............
Ron
To Melling oil pump help
