Help with HVAC Code B0333 Please
Old Apr 14, 2002 | 08:27 PM
BIGMAC2's Avatar
BIGMAC2
Default Help with HVAC Code B0333 Please
This past week my Dual Zone Outside Temp was reading crazy low. My A/C would not come on since the reading was below 34F. I had code B0333 "Outside Air Temp Sensor Open". I got a new sensor, and when I unhooked the old sensor connector I found it rusty- and one of the male pins had rusted off into the female. I did my best to drill out the old pin using a small drill bit. I reconnected the coupler. I cleared the code, but it keeps returning. I assume my drill-out of the old pin failed. I have not gone for a test drive due to bad weather. What can I do now? Will I have to get the wiring harness replaced?
Old Apr 14, 2002 | 10:25 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Default Re: Help with HVAC Code B0333 Please (BIGMAC2)
Common problem on the C5 due to water intrussion :yesnod: A good GM parts counterman can look up the connector,and it comes with the 2 wires attatched...You just need to splice it in...
Old Apr 15, 2002 | 10:18 AM
BIGMAC2's Avatar
BIGMAC2
Thanks C5-TECH. Now if I can only find a "Good GM Parts Man".
Old Apr 15, 2002 | 01:17 PM
BIGMAC2's Avatar
BIGMAC2
C5-Tech,
Thanks. I got the connector at my local Chevy dealer. I note that both the wires on the replacement connector are white. Is there no polarity issue on the sensor?
Old Apr 15, 2002 | 11:09 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
No polarity,the sensor simply measures resistance...The pink connectors supplied are "heat shrink" connectors.After you crimp them,make sure you heat and shrink em for a water tight seal ;)
Also,after making the repair,you may have to drive about 10 miles before you get the correct temp reading on the display.The sensor measures ambiant air,so you have to be moving for it to recalibrate :yesnod:
[Modified by C-5 TECH, 10:23 PM 4/15/2002]
Old Apr 16, 2002 | 06:42 PM
BIGMAC2's Avatar
BIGMAC2
Default Re: Help with HVAC Code B0333 Please (C-5 TECH)
C-5 TECH,
Thanks for all the help. What is the best way to heat shrink the wire connectors?
Old Apr 16, 2002 | 07:53 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Mini butane torch or cig lighter :yesnod:
Old Oct 12, 2024 | 06:26 PM
JAG G's Avatar
JAG G
2nd Gear
Any body ,knows where the wire the connects to the outside temp sensor goes?
Old Oct 12, 2024 | 06:48 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
I posted a wiring diagram for you on your other post…both wires go to the HVAC Module !!
To Help with HVAC Code B0333 Please
