430HP + Slicks = OOPS!
Old Mar 11, 2011 | 08:18 AM
a10secstreetcar's Avatar
a10secstreetcar
Default 430HP + Slicks = OOPS!
Hey CF,
Last night I took my FRC to the track and well I broke something.
Put it in gear and it will still freely roll, Jacked the rear up and spun the driver side rear tire and the passenger rear doesnt move. But I turn the car on and put it in gear and let the clutch out passenger rear will move but driver side will not. So Im thinking I have a broken drive side axle where it connects to the differential or intermediate shafts?
My question is where is a good place to buy axles and the intermediate shafts?
(Place to buy all of my rear end parts, I hear stock C5 axles and differentials can hold some power.)
While I have the car up I want it done correctly because I will be racing the car and dont want to go through this every pass.
Roughly making 430hp and running slicks.
Thanks for your input and advice..
Kyle
Old Mar 11, 2011 | 09:50 AM
chaase's Avatar
chaase
St. Jude Donor '12
You probably lost an output shaft. It is a common problem with sticky tires and stick shift cars. It is a standard upgrade for people who are going to drag race C5's regularly. I had mine done when I had all of the power added. I am trying to remember which side normally fails, but there is a longer one and a shorter one. The longer one normally fails (left side).
If you haven't done the clutch, you may want a new one too.
Old Mar 11, 2011 | 10:09 AM
a10secstreetcar
Originally Posted by chaase
You probably lost an output shaft. It is a common problem with sticky tires and stick shift cars. It is a standard upgrade for people who are going to drag race C5's regularly. I had mine down when I had all of the power added. I am trying to remember which side normally fails, but there is a longer one and a shorter one. The longer one normally fails (left side).
Yea I was thinking driver side output shaft. I am running a Mcleod RST twin disk clutch. I will know this weekend as Im removing the differential.
Old Mar 11, 2011 | 01:27 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Your going to like this info.... Heres a low buck rearend improvement that will help you out!
- C5, Its_Go_Time, Output Shaft Install - Left and Right: http://forums.corvetteforum.com/c5-t...post1573407966
- C5, ragtopws6 , Upgrading your C5 rear with C6 Z06 guts, : http://forums.corvetteforum.com/c5-g...-z06-guts.html
Heres a little on whats in the tranny also:
- C5 ragtopws6, T-56 Build (whats in my tranny?) : http://forums.corvetteforum.com/nort...-smoother.html
Old Mar 11, 2011 | 02:03 PM
a10secstreetcar
Bill,
I really appreciate your help! Thanks for the links..
Kyle
Old Mar 11, 2011 | 03:00 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
In case you missed it in the write ups,,, DO NOT mess with the PINION SUPPORT unless you have the specialized tool (KENT MOORE) to do the specialized set ups required.
I did the C6 output shafts, C6 clutch packs, belleview springs and the C6 cross shaft. All that went really well. The new seals make everything air tight!!
BC
Old Mar 11, 2011 | 03:05 PM
chaase's Avatar
chaase
St. Jude Donor '12
Another item to consider while you are working on the car is a line lock. They make good, consistent burn outs a lot easier.
Old Mar 12, 2011 | 12:08 PM
a10secstreetcar
Thanks guys!
Old Mar 12, 2011 | 12:30 PM
Chris Stewart's Avatar
Chris Stewart
Check out RPM transmissions, they are great! I
http://www.rpmtransmissions.com/differentialparts.html
Old Mar 12, 2011 | 02:53 PM
a10secstreetcar
Thank you sir!
Old Mar 12, 2011 | 02:57 PM
Sherminator's Avatar
Sherminator
They did a 3.73 setup with C6 Z06 guts for mine that will be installed for this season.
Bryan
Old Mar 12, 2011 | 07:14 PM
a10secstreetcar
Thanks Bryan!
Old Mar 12, 2011 | 07:43 PM
tommie's Avatar
tommie
http://forums.corvetteforum.com/perf...9-19-10-a.html
here is the thread when mine broke.. there is also a link to the vid in the 1st post...
i used some of the links bill posted when i replaced the left and right shafts in the diff
http://www.texasperformanceevents.co...ead.php?t=3359
another thread i posted on another board, listed the part numbers and some other info
Old Mar 12, 2011 | 07:58 PM
a10secstreetcar
Wow, Thanks Tommie! Great info..
To 430HP + Slicks = OOPS!
