Marine 2 cycle oil --> ethanol gas
the problem is the govt and eco **** people don't care about anything but politics, money and their personal agenda. I am for clean air but not mandating new fuels, processes etc. until they are proven, corn-gas takes food off table, raises prices on food since almost all foods have corn products in them and our govt gives corn-gas producers money or they couldn't make a profit, just like we do with the wind turbines in west texas which are mostly owned by other countries...so much for getting off foreign energy ... all it is is switching from oil to something else. obama thinks nuc energy the way to go, ask japan about that now. sometimes old is better.
http://www.fuel-testers.com/ethanol_fuel_history.html
Last fall, I paid about $10 for a 32 oz bottle of Sta-Bil. That's just over 31 cents an ounce.
From some one who owns outboard motors, you will need fuel stabilizer if you allow your fuel to age more than 60 days. Two stroke oil will leave the inside of a carb (or any other metal container) very clean and shiny. I just removed 2 carbs from one of my outboard motors. Though it had been sitting for several months and I expected damage from ethanol, it was perfectly clean due to a vro pump issue (too much oil oil injected into the fuel system). The fuel system was full of 2-stroke oil. That was a nice surprise, but the new pump is $400.
As far as ethanol in the fuel system, it will destroy an alumnium fuel tank (and carb bowl)if the ethanol and gas is allowed to seperate. Use a fuel stabilizer to prevent phase seperation of fuel if the fuel will not be used within a reasonable amount of time.
Only experience I've had with 2-stroke oil in a car's fuel tank is some one dumping a bottle of 2-stroke oil in the fuel tank of an unsuspecting person (cruel joke) and following the "trouble shooting" procedure.
I don't know enough about this to have an opinion as to whether this is a good or bad thing to do, but I wiil share what I know as it relates to 2 stroke engines. I ran Torco GP7 2 stroke full synthetic oil in my 200 HP Evinrude engine. I chose that oil, because it was an ashless formula. The byproducts of combustion were water vapor and a gaseous compound. I sold that engine with many hours of use, and it had perfect compression, at a time when carbon buildup on the rings was a big problem in those engines. If I was going to use 2 stroke oil as an additive in my C5 fuel tank, I would use that oil or something similar.
Why is there even a mention of diesel or 2 stroke engines? They operate completely different from a 4 stroke engine.Folks here complain about oil residue in their intakes all the time,why would you add oil to the fuel?
It may be even better than what I'm talking about.
But it would also be more expensive than 9.4 cents an ounce.
Then again, thousands of people smoke and never get cancer.
All TCW-3 rated 2 stroke oils are ashless and burn completely.
