F55 shock question
Old Mar 12, 2011 | 10:43 AM
duosy's Avatar
duosy
Default F55 shock question
Will codes be shown if the F55 shocks are leaking fluid? There are no codes that I can find in the 2004 shop manual - but that does not mean there are none.
Old Mar 12, 2011 | 03:19 PM
Bluefire's Avatar
Bluefire
I'm not sure if there is a code for a leaky shock. Are you seeing a leak? If you are, would you need a code to verify it?
Old Mar 12, 2011 | 04:04 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
NO.. Nothing monitors fluid level or shock pressure so you will NOT see a code for a worn out or leaky shock.
You can disconnect one end of the suspected shock and see if it has proper dampening and the correct intarnal pressures. When you disconnect the lower end, the shock should expand on its own.
BC
Old Mar 12, 2011 | 04:43 PM
duosy's Avatar
duosy
Thanks for the info. Probably will get some C6 shocks as soon as winter is gone from Michigan.
Old Mar 12, 2011 | 05:01 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You will need this post so you dont get DTCs and speed limit restrictions. You have to eliminate the F=55 function.
http://forums.corvetteforum.com/c5-t...post1577034498
To F55 shock question
