Steering rack removal HELP
Old Mar 14, 2011 | 02:11 PM
RealmSteel's Avatar
RealmSteel
I thought about that when I did mine, but the prybar worked so I didn't.
You already have the rear up and supported. I would just move the front supports to the puck locations.
Where do you plan to jack the car up to be able to jack stand it under the puck locations?
Old Mar 14, 2011 | 02:26 PM
RealmSteel's Avatar
RealmSteel
I notice your car is an automatic.
How are you going to keep the crank from turning when loosening the damper bolt?
Here is a link to pictures of a tool I made from scrap around the shop I manage.
http://s918.photobucket.com/albums/a...teel/Corvette/
Old Mar 14, 2011 | 02:43 PM
VET IT B's Avatar
VET IT B
I can put the jack back in the middle of my 2X6, between the 2 front jack stands, jack it up a bit and move the stands to the outside front rails with pucks installed.
Old Mar 14, 2011 | 02:45 PM
VET IT B's Avatar
VET IT B
I already have the tool that fits into the flywheel where the starter goes.
Old Mar 14, 2011 | 04:42 PM
81c3's Avatar
81c3
Wow, I havent heard of anyone having this much trouble with this.... Mine came out with a few prys of the prybar and a little manipulation. I cant understand what can be holding it from coming free.
Old Mar 14, 2011 | 06:42 PM
Cratecruncher's Avatar
Cratecruncher
Using the puck locations should be fine. (I don't have pucks so couldn't use that spot when I did mine.) Before unbolting stuff I'd locate a hydraulic jack under the engine in a high strength spot and distribute the load with another chunk of wood. Then I'd remove the engine mount bolts. Then I'd slowly back off the subframe to chassis mounting bolts evenly, one revolution at a time, until I got the rack freed but no more. My big worry with screwing with that subframe is that the front chassis spring is still under tension even with the cars weight off the front suspension. I wouldn't loosen those nuts past full thread engagement. If the rack isn't free by the time I ran out of threads I'd stop and try something else.
I haven't actually done this so if someone has a better idea......
Old Mar 14, 2011 | 07:37 PM
VET IT B's Avatar
VET IT B
I hope to try and get some time on Tuesday or Wednesday to get back at it. I will keep you posted.
Anyone else have any ideas, I'm all Thanks, Mark
Old Mar 14, 2011 | 07:38 PM
LMDNC5's Avatar
LMDNC5
St. Jude Donor '11-'12-'13-'14-'15,'19
I have done three cams in my car in the last year. never lowered the sub frame. If you get it back where it belongs pry the passenger mount toward the drivers side. you should get to the point of rotating it to slide out thru the drivers side sub frame opening. order new rack mounts from Napa or someplace yours look pretty worn
Old Mar 14, 2011 | 08:12 PM
01vetter's Avatar
01vetter
Lube those rubber bushings. You can use some silicone spray or grease. That made a big difference when I was removing mine. It looks like your rack is pinching the bushings.
Old Mar 14, 2011 | 08:23 PM
Paul 75 L82's Avatar
Paul 75 L82
Looking at your #2 picture it looks like part of your problem is with the rubber washers. The rubber washers have a metal insert that fits in the hole of the flange and is sweged to the flange. They should not move when you lift the rack. The both of them are attached to the flanges. I think the reason the rack is not lifting is that the rubber washers are causing an interference. There was a thread a couple of weeks ago about these washers. Bill Curlee had some good info on that thread. I think you need to call Bill and talk to him about your problem. Send him a PM, he's a great guy.
Old Mar 14, 2011 | 08:38 PM
Paul 75 L82
Here's that thread.
http://forums.corvetteforum.com/c5-t...k-problem.html
Old Mar 15, 2011 | 09:13 AM
VET IT B's Avatar
VET IT B
Thanks Paul. I sent Bill a PM.
Old Mar 15, 2011 | 01:26 PM
  #33
VET IT B's Avatar
VET IT B
I'm not there yet, but I did get the rack back into it's original location.
I loosened the cradle bolts, put a shim in between the frame and cradle and that allowed me to get the rack rotated back into the cradle. A backwards move but its at lease back in it's original place.
The drivers side is loose and I can move it up and down by hand. Some of the rubber bushing around the cradle ears on the passenger side are gone with all the prying I've done.
With a pry bar put between the ears from the passenger wheel well, I can move the steering rack up only slightly. It is still tightly in there.
Should I just start prying it up again or try to move it sideways towards the drivers side wheel well? Mark
Old Mar 15, 2011 | 01:57 PM
  #34
RealmSteel's Avatar
RealmSteel
Move it towards the driver's side and remove through the driver's wheel well
Old Mar 15, 2011 | 04:23 PM
  #35
VET IT B's Avatar
VET IT B
SUCCESS!!
Thanks so much to everyone who offered assistance and help. It all helped me get this accomplished.
This part, so far, has been an experience. I must admit that I probably caused it myself by getting the rack wedged sideways. Once I got it back into place, by leaving the drivers side in place between the ears on the cradle and prying up on the passenger side, I was able to get it up straight because the drivers side was still between the ears keeping the rack aligned and straight.
I am probably lucky that I didn't brake off the cradle ears when I got it wedged sideways. Thanks to everyone. Now on with the show. Mark
Old Mar 15, 2011 | 11:03 PM
  #36
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Well.. I got your request for help late but,, I am glad you forged ahead..
Here are some tips that I learned about damper install and removal. Heat is your friend. Heat the damper hub to about 150 deg with a torch or heat gun and it makes getting the damper on and off a WHOLE LOT EASIER!!
Like in the post that was referenced, I too use a strap wrench to hold the damper. Works SUPER! The tool you have works SUPER TOO.
I used the ARP Damper bolt with out issues. Rent the 0-250 ft/lb torque wrench and three jaw puller from AutoZone.
Save your old damper bolt to SEAT the new damper. I made my OWN damper install tool from an old bolt and some SAE All Thread. DO NOT be tempted to start the damper on with the old bolt. Some people have damaged their crank snout threads that way.
BC
Old Mar 16, 2011 | 07:19 AM
  #37
VET IT B's Avatar
VET IT B
Thanks for the tips Bill. They are appreciated. Mark
