Question about Cams...
Old Apr 15, 2002 | 12:49 AM
NYtoCA's Avatar
NYtoCA
Default Question about Cams...
I'm not quite ready to drop $6-$10k for heads and cams but from what i've seen you can get just a cam for about $400?
What are the reported power gains from just a cam?
I heard that labor is not that much?
Is this what causes the "lumpy" idle?
Thanks in advance,
Frank
Old Apr 15, 2002 | 12:28 PM
NYtoCA's Avatar
NYtoCA
Default Re: Question about Cams... (NYtoCA)
anyone? :D
Old Apr 15, 2002 | 12:42 PM
MattG's Avatar
MattG
Cruise-In I, II, III, IV & V Veteran
CI-I & II Auto-X Champ
Sure a camshaft alone is around $400, but then you have to also do valvesprings and pushrods which add up to about another $300, and then usually $600-1000 for install depending on shop. Also, to get real good power out of a cam-only installation, you will also have to get some sort of PCM programming done, or at minimum a $300 Hypertech Programmer to raise the Rev Limiter of your car. Also, to get the true 20-30rwhp gains from a camshaft, you also need a set of Long Tube headers which start around $900 for the lowest cost ones.
There are a lot of factors that go into camshaft seleciton as well, A4 or M6 car? Does it have to pass emissions? Do you mind a bit of a lumpy idle?
Old Apr 15, 2002 | 03:58 PM
vstella's Avatar
vstella
I know how you feel :yesnod: After all my research I ended up wih a great package by ARE(Agostino Racing Engines) They have a great bang for the buck head and cam deal for the budget minded and I gained over 45 RWHP and 20 RWT with this "Street Eliminator" package on my 2001 Coupe.
You get a set of competition heads Ported and polished intake and exhaust with NEW stock size valves, NEW Compcam 918 springs,retainers and seal,pushrods.for $1650......That's a value ,believe me!!:yesnod:
Listen to the results :eek: http://www.badazcorvettes.com/~vstella/video/ARE226.mpg
Old Apr 15, 2002 | 07:05 PM
Red Gump's Avatar
Red Gump
Default Re: Question about Cams... (vstella)
vince, is your c5 your daily driver? I'm seriously considering the street eliminator but am concerned I'll be too loud afterwards.
Old Apr 15, 2002 | 07:32 PM
4THTOY's Avatar
4THTOY
Vstella
I looked at ARE's web site and did not see any information about their "Street Eliminator" package , do you have some information you could share?
Old Apr 15, 2002 | 08:27 PM
ifeeltheneedforspeed's Avatar
Mike Norris at Norris Motorsports tells me that a cam (Comp 216/220, 114) w/springs, retainers, plus installation will cost me $1500. He believes I would get an incremntal gain of 20 to 30 hp on my FRC that already has a Donaldson, ported maf, ported tb.
I have the same problem. Don't have the deep pockets to drop 7 or 8 large at one time. I have asked for his suggestion on how to build up to a comprehensive system (H&C, headers, exhaust, pulley, ls6 intake) by spending $2k every so often till I get there.
Old Apr 15, 2002 | 08:35 PM
vstella's Avatar
vstella
Default Re: Question about Cams... (3rdtoy)
Red Gump...Yes it's a daily driver ...In fact I just back with the groceries. NO problems at all:yesnod:
3rd Toy....The package IS available, but not on the website yet.You can call Nick Agostino direct at ARE or Matt G at Exit 28 motorsports.The package is $1650 with heads and a choice of cam!! You can't beat the deal ...I tried! :D
To Question about Cams...
