no power steering... help!!
Old Mar 17, 2011 | 04:06 PM
cracker Bear's Avatar
cracker Bear
Ok. It's magna steer.. I've found the two pin plug and it's been plugged in the whole time.. Yes the res is full. I pulled the pump and spun it back and forth trying to get it to move fluid and I got nothing... Kept messing with it and pouring fluid in it and now it shoots fluid when I spin it by hand.. Should I put it back on and hope for the best or should I be chasing down the magna steer wires to see if there is a break somewhere.. Or I guess the real question is .. If there was a short or break in the magna steer wires would it cause my problem?
Old Mar 18, 2011 | 02:57 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Have you pulled the codes yet and hope to see a magna steer possible code report?
Old Mar 20, 2011 | 10:16 PM
cracker Bear
codes from magnasteer??? i dont have any check engine lights on if thats what your talking about... still havent answerd the question, would magnasteer cause this problem?
Old Mar 20, 2011 | 11:26 PM
99FewteRC5's Avatar
99FewteRC5
Magna steer shouldn't cause a no p/s assist issue, You would have lack of assist but some assist. Take a screw driver and pry on the p/s pump pulley a little, the pulley should not slid out. This ensures that the shaft is not broken internally. (common on gm trucks)
Old Mar 20, 2011 | 11:57 PM
lucky131969's Avatar
lucky131969
Originally Posted by 99FewteRC5
Magna steer shouldn't cause a no p/s assist issue....
Next time you go for a ride, disconnect it, and tell me how it feels.
Old Mar 21, 2011 | 12:41 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
I've lost my power steering pump before and it felt much more difficult to steer than with the plug disconnected. Maybe I've just gotten stronger
