Running rough then dies
The contacts for the relay was the inboard most forward contact as you just indicated, but this is contact 86 not 85. I got this info from the bottom of the relay. I wasn't able to see your pictures or anyone elses either. I don't know if its something that I am not view correctly or not. Tried two different computers.
The relay sockets are like this:
87 86
85 30
forward -->
Does this match what you think?
Thanks again for your assistance.
I tried to avoid confusion, by posting a picture for reference. The relay can be inserted two ways, because contacts 85 & 86 are diagonal from each other, as are 30 & 87. So going by the bottom of the relay, depending on which way you insert it (into the socket), would be your point of reference for ground being at 85 or 86.
I thought by posting directions, and a picture with corresponding numbers, it would have made it simple, but I should have provided more info. Sorry for the confusion.
Different question, can you patch or plug a a run flat tire? While under the car I noticed a small nail in one of my tires. It is in the read area so not a side wall issue.
