Turn Signal Help
Old Mar 17, 2011 | 09:40 AM
DavidF44's Avatar
DavidF44
Cruising
Default Turn Signal Help
Hey Everyone, I just purchased my first Corvette and I have found a small (I hope) issue. I have a 2000 Corvette Convertible 6 Speed. When I am driving the car, the turn signal will work off and on. When I use the lever to signal, it will turn on sometimes and then other times there will be nothing there on the heads up or the normal dash. It is like there is no power to it at all. I was just wondering if anyone else has had this issue or if there is a quick fix. I am ready to enjoy my car and this is something I really need to get fixed.
Thanks in advance.
Dave
Old Mar 17, 2011 | 02:35 PM
craig04c5's Avatar
craig04c5
Good info! I just went to the site and they are out of stock though so we'll have to wait for them to re-stock.
Old Mar 17, 2011 | 04:43 PM
Rich Silvestris's Avatar
Rich Silvestris
St. Jude Donor '05
Another cause for this can be corrosion at the lamp connector. The front housing is prone to water leakage. While you are waiting to source a hazard switch, you might want to check for this. Search for suggestions on how to change the lamp, and while you are in there, clean the contacts. Worked for me .... AFTER I had already changed the hazard switch!
Old Mar 17, 2011 | 04:59 PM
johnson-rod's Avatar
johnson-rod
While you are waiting, you can also switch on and off the hazard lamps a few times to see if the switch is just corroded. Sometimes just working it will bring it back to life for a while.
"This is only a temporary fix, unless it works."
Old Mar 17, 2011 | 06:23 PM
Wolfmanjohn's Avatar
Wolfmanjohn
This worked on my son's Z28; he had intermittently slow blinkers on alternating sides. Just have to exercise things once in a while, like the passenger window motor.
Old Mar 18, 2011 | 08:48 AM
DavidF44's Avatar
DavidF44
Cruising
Thanks for all of the help. I did play with the hazard switch for a little while last night and that was intermittent at first and then after a while with pushing it is seemed to work. The car did come out of Florida, so the change in climate may have messed with it a little also. Hopefully this will work for a while until I can locate the bypass. What exactly does the bypass do? The signals will work without using the hazard switch with this?
Thanks again!!
Dave
Old Mar 18, 2011 | 09:32 PM
RSchleder's Avatar
RSchleder
The bi-pass cable totally bi-passes the OEM switch and provides a plugin replacement. It's definitely the way to go. I installed mine in my 2000 convert 3 years ago and it has been rock solid. The temp fix suggested above is also very good advice. You might even try spraying some PLASTIC SAFE electrical contact cleaner into the OEM hazard switch ( around the edge of the button) before exercising it 15-20 times. I did this on/off for a year before I actually bought and installed the bi-pass cable. Good luck, Ron
PS: The bi-pass cable costs about $65 and takes 20-30 minutes to install depending on handy you are.
Old Mar 18, 2011 | 09:50 PM
TNRAT's Avatar
TNRAT
Originally Posted by 8VETTE7
Most likely it is the flasher that is failing. The emergency hazard switch on the dash has the flasher unit for both the signals and hazard switch and are common failures on these cars..Difficult to get the haazard switch out (significant disassembly. Most use a bypass which is available at JW Motoring and other places:
http://shop.jwmotoring.com/searchqui...rds=hyperflash
The bypass fixed mine too....
Old Mar 18, 2011 | 11:28 PM
Mrgogo's Avatar
Mrgogo
My brake lights didn't work because of the bad flasher unit. I pulled up the center console and pulled out the radio to get to the flasher unit. Sounds like a PITA but it was actually quite easy. Flasher unit cost me 40 bucke from the dealer. about and hour and a half to fix. I did it and I'm not a pro. Do a search and I'm sure you'll find the step by step instructions somewhere here. Good luck!
To Turn Signal Help
