Plastic liner difference, missing part?
Old Mar 17, 2011 | 04:02 PM
C5_Z06's Avatar
C5_Z06
Default Plastic liner difference, missing part?
I noticed the left and right plastic liners behind the front wheels are different on my car. Is something missing or should the drivers side have an open end towards the engine?
If something is missing, is that part available separately?
Some pics, sorry for the bad quality.
Old Mar 19, 2011 | 01:37 PM
lucky131969's Avatar
lucky131969
Originally Posted by Jewjenk
Is it the panel where the PCM resides behind? is it possible that someone re-flashed the PCM and did not replace the panel?
From the OP's first post: "Is something missing or should the drivers side have an open end towards the engine?"
Old Mar 19, 2011 | 01:51 PM
Jewjenk's Avatar
Jewjenk
Sorry, just deleted my last post, the PCM is on the passenger side..............I should know better
Old Mar 25, 2011 | 04:26 PM
KENCO's Avatar
KENCO
St. Jude Donor '11
I deleted my original post here because I commented in error. Sorry
Old Mar 25, 2011 | 04:58 PM
KENCO's Avatar
KENCO
St. Jude Donor '11
Error in posting
Old Mar 25, 2011 | 11:53 PM
byronhunter's Avatar
byronhunter
Not true!! The left side is NOT supposed to be closed off like the right side!
Old Mar 26, 2011 | 07:53 AM
KENCO's Avatar
KENCO
St. Jude Donor '11
I just rebuilt the entire front end of my car, and from memory I recall them both having a stapled pc on them................if I am wrong i apologize.
Old Mar 26, 2011 | 01:05 PM
C5_Z06's Avatar
C5_Z06
Old Mar 26, 2011 | 02:22 PM
byronhunter
So, now how much is it worth?
Old Mar 26, 2011 | 02:31 PM
1999_TRC's Avatar
1999_TRC
Why make a comment, if you don't know for certain? Reading your post, I got the impression, that you actually knew for sure, not just commenting from "memory".
"Yes they should be the same. The piece is missing, you have to buy the entire piece. Your section that is missing is stapled on from the factory and its a wonder how they stay on as long as they do, a real piece of junk. "
Old Mar 26, 2011 | 07:07 PM
C5_Z06's Avatar
C5_Z06
Quite a bit more. Cheers buddy! My car is ok then, one less thing to worry about. Case closed.
My experience is that it happens quite a lot here, unforunately.
Old Mar 26, 2011 | 11:10 PM
jedblanks's Avatar
jedblanks
hmm, now I have to go outside and crawl under my car because I don't remember those on either side. Thanks.
Old Mar 27, 2011 | 12:15 AM
byronhunter
Why would you do that, pictures ar posted.
Old Mar 27, 2011 | 02:58 AM
C5_Z06's Avatar
C5_Z06
Fwiw I can tell you it's supposed to be on the passengers side for sure, but not on the drivers side I guess based on the replies above
Old Mar 27, 2011 | 05:50 AM
KENCO's Avatar
KENCO
St. Jude Donor '11
Sorry about that, I remember I had to fix some of those stapled together pcs thru out the front end. Like I said before I am always big enough to apologize when I am wrong, so sorry if it was an inconvenience to anyone........
To Plastic liner difference, missing part?
