Radiator leak
Old Mar 17, 2011 | 07:02 PM
Extra260's Avatar
Extra260
Default Radiator leak
Started the Vette today only to find that I have a leak at the upper radiator hose. I cut the end off the hose thinking the clamp may have cut the hose, re-installed it and I still have the leak. I didn't have time to look any further. Anyone else ever have this issue?
Mark
Old Mar 17, 2011 | 07:22 PM
lucky131969's Avatar
lucky131969
Mark
Yes. I have had a radiator leak before. Post back when you have time to look at it, or take a pic.
Old Mar 17, 2011 | 07:29 PM
Extra260's Avatar
Extra260
I did have a chance to feel around the hose. Right now my guess is the plastic nipple the hose slides over is cracked. I couldn't see in there very well. I'll have to pull the radiator cover to get a better look. I wonder if it is the nipple if it can be repaired?
Old Mar 17, 2011 | 07:41 PM
lucky131969
Nothing you can do yourself. Sounds like you need to take it to a trusted shop.
Old Mar 17, 2011 | 08:20 PM
TOPGUN9's Avatar
TOPGUN9
Default radiator leak
My 1999 C5 is in the shop right now for a radiator. I did a search, and leaks under the upper radiator outlet are common. It's almost impossible to see the crack unless you remove the radiator.
Old Mar 17, 2011 | 08:22 PM
Extra260's Avatar
Extra260
I assume it can be fixed even if it is in the plastic?
Old Mar 17, 2011 | 09:13 PM
lucky131969
Sure. You can have them fix that side, and two weeks later, have the other side fail. If it's got to be pulled, I'd replace.....
Old Mar 18, 2011 | 05:53 AM
C1 Eire's Avatar
C1 Eire
I agree. I had a leak in the same place and pulled the rad. and got it fixed but I wasn't impressed with the repair so I just replaced it. I'm sorry I didn't just replace it first day as it would have saved me time and money.
Old Mar 18, 2011 | 09:39 AM
Extra260's Avatar
Extra260
Did you Guys replace with a GM radiator or go aftermarket? It doesn't look to difficult to pull so I will most likely do it myself.
Old Mar 18, 2011 | 09:59 AM
lucky131969
Depends what your intentions are for the car. If you wish to keep it original, the GM is the obvious choice. If it's just a driver, then a quality aftermarket replacement will suffice. If you plan on racing, then you would want to upgrade to a Dewitt's, Ron Davis, etc.
Old Mar 18, 2011 | 10:25 AM
mcintex's Avatar
mcintex
St. Jude Donor '06-'07
But I would also add that after I installed a DeWitt radiator, my car ran cooler. Both the Ron Davis and Dewitt are designed for your C5 and have better cooling (more rows). It is not a hard swap, and the money you save on the install should pay for the better radiator.
FYI, my friend and I did both (him=RD) and he captured the install with pics and instructions. Search in the Autocross section. I ended up adding a secondary trans cooler because I like to do HPDE with my old 98 A4.
Old Mar 18, 2011 | 08:16 PM
TOPGUN9's Avatar
TOPGUN9
I went with OEM since I'm stock. A DeWitt radiator is far superior, but significantly more expensive. By the way, I just took a look at the old radiator, and the crack was above the upper neck, not below like I thought.
Old Mar 18, 2011 | 08:25 PM
Extra260's Avatar
Extra260
Just finished pulling the radiator out as I found a crack in the same location as youirs. Since mine is stock as well I will be getting a stock radiator to go back in as well. I hope it goes in a little easier than this one came out!
To Radiator leak
