My C5 was in my barn for over 2 years and would not start so I changed the battery and the fuel filter and the engine just won't turn on. It cranks fine and when I spray starter fluid into the throttle body it will turn on for 2 seconds and then turn off. I do not hear the fuel pump cycle when I turn the key when I so I suspect that no gas is getting to the engine . What is the next step I need to do other than call for the tow truck. Come on corvette brethren I need a solution. Thanks.
check your fuses. You might have just blown a fuse for the fuel pumps. If you have to get to them, remove your rear wheels and pull the plastic wheel well covers on the front side. The wiring might have been a target for critters.
Fuse #13 and relay #35 in the engine compartment fuse box. If they are good check to see if any wiring may have been eaten by rodents.
Also check grounds. G401 on the left rear outer frame is the fuel pump ground.
Might also pull the codes to see if there is one that is preventing the pump from getting power.
You won't know for sure if it's your pump until you put a gauge on the rail and check pressure. Lots of possibilities in a car that has been sitting for 2 years. Was it in good condition when parked?
If you know how to use a meter, and read schematics, then you can easily troubleshoot it.......if not, a tow is in order. If you did not take precautions to protect the car, rodent damange is a distinct possiblity. A cursory inspection of the engine bay, and under the car for pieces of wiring insulation is in order.
As others have said, spend some time with the car before subjecting yourself to a rapacious dealership or shop experience.
If you are not comfortable working on the car, perhaps a mechanically-inclined friend will help. Or maybe there is a Forum member in your area who might assist.
You might literally save a thousand dollars or more.
I pulled fuse#13 and it looked fine but I couldn't pull relay#35 out. I was scared that I was going to break the relay. Do you just keep pulling up as I used a set of needle nose pliers and it did not seem to want to come out. And yes those nasty rodents had set up a plush home with straw and leaves on top of the battery and I also found a rat home inside the front fender just below a pump that was placed there for my methanol system. I looked in the engine bay and inside the front fender but I could not find any eaten wires. I will take down the left rear wheel cover tomorrow morning to see if they got to the fuel pump ground wire. These rodents are the probable culprits, but I just went to walmart and got 90 tablets of warfarin so that this doesn't happen to my other cars. Sorry if there any peta lovers but they gotta go.
What type of guage do I need to buy and where is the rail and where do I connect it to and what type of pressure number am I looking for. You can tell that I am a novice by the questions but you gotta learn sometime. thanks. BTW the rodents had set up a large bedroom on top of the battery and inside the front fender but I could not find any cut wires. Thanks
Look on the drivers side fuel rail. On the FRONT of the rail, you will see a black cap. Under the cap, is a schrader valve. Any auto parts store will sell a schader type fuel pressure gage.
It just screws on to the end of the fuel rail. Theres a valve inside the schrader (just like a tire valve stem) that the fuel pressure gage presses on to allow the fuel to leave the fuel rail and enter the gage.
BC
I checked fuse#13 and relay#35 by switching them from my other vette and fuel pump does not cycle when I turn the key. Can someone post a picture of where this schrader valve is so that I can check the fuel pressure. Thanks.
"a pump that was placed there for my methanol system."
What kind of mods do you have? You may not be using the stock fuel rail. The valve is not hard to see and is the only thing capped off in that area.
