What are the difficulties to put in a 2006 Z06 Ls7 into 2000 C5 Convert with automatic trans? the Z is a 6 speed What is needed to to convert the dry sump to a wet sump or can the wet sump be installed in the vert?
ALSO WHAT IS NEEDED TO PROGRAM THE REMOTE WHEN NONE ARE WITH THE CAR sorry for the caps getting too oldhttp://images.ibsrv.net/ibsrv/res/src:forums.corvetteforum.com/get/images/smilies/willy_nilly.gif
If I do this I will have a complete donor car. Will wiring harnesses form the 2000 work with the z06 will ECM plug into existing harness?I need as much info before I buy the donor. Thanks Gene
I know you're a new member but you should really try to perform the search and find out yourself. Here is what I found. A lot of good usable information here:
You keep your existing wire harness and PCM but you MUST either change the crank reluctor to a 24 tooth or use LPE's converter-box like ragtopws6 says.
There are a couple sources for plug-n-play wire harness extensions for your MAF sensor and crank sensor and new location for your knock sensors (side of the block). You may need headers as well, just be sure the header company knows you need the correct flange for an LS7 to bolt up to the heads. That's not a big issue though and easily done.
Personally I would change it over to a wet sump and not have to deal with mounting the oil tank and relocating the battery to the rear of the car, etc.
Needless to say, a custom tune will be necessary.
Scoggin-Dickey can be a good source for a lot of your needs or maybe Katech as well.
