which optima battery should I go with
Old Apr 15, 2002 | 05:03 PM
BRIANS1999VETTE's Avatar
BRIANS1999VETTE
Default which optima battery should I go with
I see the red top and yellow top .which would be best for an everyday driver. :cheers:
Old Apr 15, 2002 | 05:12 PM
Dale RED 98's Avatar
Dale RED 98
Default Re: which optima battery should I go with (BRIANS1999VETTE)
Either! I believe the yellow just has more amp's and cranking power.Red should be fine and cost a little less. Just my opinion! :cheers:
Old Apr 15, 2002 | 05:33 PM
C5-VERT's Avatar
C5-VERT
Cruise-In IV Veteran
Default Re: which optima battery should I go with (Dale RED 98)
Yellow is a deep cycle. Designed to be depleted and recharged more often w/o killing a cell. Primarily used for boats, etc. Either one will work though. But the red should do just fine... :cheers:
Old Apr 15, 2002 | 06:04 PM
UFOVette's Avatar
UFOVette
Go with Red top designed for Automobiles. More cranking amps. Yellow top is deep cycle marine battery. Will also work with cars.
Old Apr 15, 2002 | 07:04 PM
blackjack's Avatar
blackjack
Red top works great for me.
-BlackJack :flag
Old Apr 15, 2002 | 11:52 PM
KY 99 C5's Avatar
KY 99 C5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
I have the Red Top on My 99. Works Great.
Old Apr 16, 2002 | 12:46 AM
rhoeven's Avatar
rhoeven
Daily driver: Optima Red Top
Weekend driver or less: Yellow top
My '99 normally gets driven a couple times per week but sometimes even sits for 2 weeks without starting. I have the yellow top for almost 3 years now. Never had a problem.
Hope this helps
Roger
Old Apr 16, 2002 | 01:10 AM
Ricksc5's Avatar
Ricksc5
Default Re: which optima battery should I go with (rhoeven)
Roger is right on target. :yesnod: :yesnod: :yesnod:
To which optima battery should I go with
