Possible problem with instrument cluster dimmer?
Old Mar 21, 2011 | 01:01 PM
Cybermind's Avatar
Cybermind
Default Possible problem with instrument cluster dimmer?
Hi guys,
I'm not sure if I actually have a problem or it's because I never noticed it before but is the backlit UV instrument cluster brightness supposed to vary with the dimmer switch. When I turn the **** everything else (DIC, AC, Radio display) dims but not the instrument cluster lighting. Is it supposed to or is it at a fixed brightness? I know that it uses UV compact fluorescent bulbs which usually cannot dim. Am I correct?
