p0343 with new ls2 install
Old Mar 22, 2011 | 09:56 PM
long's Avatar
long
Default p0343 with new ls2 install
Guys is there a difference in way the pcm counts for the cams on a ls1 vs ls2. I am thinking of how the cranks have a 24x for the ls1 and a 58x for the ls2. I have a P0343 code but I am sure the bolts are tight since I just installed them. I even took extra care to loctite them because I know the can loosen over time. Any suggestions would be great.
Old Mar 22, 2011 | 10:08 PM
lucky131969's Avatar
lucky131969
Two possibilities:
1) Your adapter harness is not pinned up correctly(very common)
2) You have a 4x cam gear, and your PCM wants to see a 1x
Old Mar 22, 2011 | 10:18 PM
long's Avatar
long
Lucky
If I have the wrong cam gear can this be corrected with software such as hp tuners. Also I was talking to the owner of the car about the harness possibly being the problem. Thanks for your quick response.
Old Mar 22, 2011 | 10:19 PM
lucky131969
Lucky
Give me a call. PM sent.
Old Mar 22, 2011 | 11:07 PM
Gitusum's Avatar
Gitusum
did you guys figure out the problem or have a idea what it may be?
Old Mar 23, 2011 | 06:21 AM
long's Avatar
long
Gitusum. I am going to check the wiring. I will let you know how it turns out.
Old Mar 26, 2011 | 06:02 PM
long's Avatar
long
Lucky Thanks for you help with this problem. Just so everyone knows what fixed the car.
1. Wire harness was not correct. I had to swap the outside wires.
2. After fixing the harness the car still throw the code and was hard to start. Checked sensor and found it was shorted. I replaced the sensor and we are good to go.
Old Mar 26, 2011 | 06:04 PM
lucky131969
Thanks for the follow up. Was it the red and black wires?
Old Mar 26, 2011 | 06:16 PM
long's Avatar
long
You are correct. The red and black wires were the problem
Old Mar 26, 2011 | 06:19 PM
lucky131969
Glad you got it worked out.
Old Mar 27, 2011 | 05:49 AM
Rob's 73's Avatar
Rob's 73
I had this problem about 2 1/2 years ago. Hard to believe they are still making the conversion harness wrong.
To p0343 with new ls2 install
