Roller Rockers
I personally have Harland Sharp but I have trick flow heads and after market rockers are recomended for them. Alot of people like the Yella Terras and Jessels can be really expensive. The main thing about them is setting them up correctly.
Theres really no point in doing after market rockers.
the stock rockers are quite good and good for the motor. if the swipes were bad on the valves, it may have been assembled wrong or abused.
who would abuse a corvette?
but
wth massive cams and big *** valves/heads, you need aftermarket
You have that rather backwards my friend. The stock rockers are no doubt a lot cheaper to manufacture with a flat tip than adding a roller bearing tip.Until you have marked the end of a valve and rotated the cam through it's lift cycle, you may not fully understand what Vettenuts is talking about. It doesn't take a large cam (i.e. my 224/230) for side loading with stock rockers to become a real problem. Not saying that stock rockers aren't strong - just that the flat tip absolutely will not give you a tight contact patch on the valve tip once you increase cam lift.
I would encourage you to actually pull a couple rockers off, mark them, and then come back and comment in this thread.
and to the OP - any of the rockers that you listed will be quality pieces. Find a good price and buy them.
1 - The stock rocker arm is excellent- especially with the above mentioned Comp Cams trunnion upgrade
* Rigid and lightweight
* Low Cost
* Carry High RPM without "nosing-over"
* Reliable and easily available
2 - Lower Cost Roller Rockers
* many will nose over above 6500 RPM ( tip weight)
* Most are not adjustable
* Some require a taller valve cover or valve cover spacer
* Available in offsets and various ratios
3 High end roller rocker arms - Jesel, Crower, T&D -
* Available in all ratios as well as adjustable and non-adjustable.
* Available in any offset or ratio
* Require a taller valve cover or valve cover spacer
* May require cylinder head machining to mount
* Low Cost
What do you mean by "nosing over"?
* Low Cost
What do you think of the SLP 1.85s? They are the stock rocker arm with the Comp trunion upgrade installed by Comp and made into 1.85 rockers.
Ed
A cheaper alternatine is a yella terra lightweight rockers.
My 346 h/c made peak hp just over 7000rpms and lost about 10 hp up to 7500rpms.
Swipe pattern and geometry is important.
Ed
