Okay, electronics is a weak area for me, so I was hoping someone may have a picture or two, of the straight cord for a PASSPORT RADAR Detector (link below).
You do know about the AUXILIARY 12 VDC on the 97-2003 C5 in the passengers foot well. Its made for just what your doing. Theres a hot and a switched wire for that purpose:
Its to the left of the BCM and if it was never used, it will be wrapped in tape:
Its on a plug so you can disconnect it and wok on it at a bench.
Thanks Bill, I knew there was something down there, wasn't sure where. However, in the picture I can't make out which wire is what. Sorry brother, could you help out?
I used a 16" quick connect wire that plugs into the back of the mirror and a mount/clip that attached to the top window frame. VERY easy to do! Works & looks great!
E-mail me and I'll send you pictures. bill.clark8@gmail.com
I have the 12" just like that one and the wires have backed out everytime I have drove it. I have used electrical tape, zip ties and both and it keeps backing out, so I am done with the mirror connection. I had the long one going to the fuse box and it worked great, but I did not install it. If anyone wants the 12" I have send me an address and I'll give it to you.
