Harmonic balancer questions
Old Mar 25, 2011 | 11:31 PM
MyEBc5Z's Avatar
MyEBc5Z
If you do go with an ati balancer and want to pin it, I have a pinning kit i will sell to you
Old Mar 26, 2011 | 12:49 AM
shift's Avatar
shift
how much
Old Mar 26, 2011 | 01:25 PM
LT70ZR91's Avatar
LT70ZR91
I am interested in you ATI Pinning Kit. I have a motor on the engine stand and an ATI Balancer waiting to go on. Don't you drill the crank before the balancer is installed?
I am close to Chicago and might be able to pick it up. How much do you want? Do you have any extra pins? How many cranks have you drilled with it?
Old Mar 26, 2011 | 02:15 PM
81c3's Avatar
81c3
Impressive using the dial indicator!! Any axial movement at the balancer is bad. I wouldnt drive the car myself, but Im a the cautious type. You can buy a nice Powerbond balancer for around $200. Theyre made in Australia and theyre a quality piece. Theyre availabe in 10% & 25% underdrive as well as stock size. Heres a pic of mine (25% UD)
Old Mar 26, 2011 | 04:04 PM
69SSC5's Avatar
69SSC5
Originally Posted by FRCTony
Just make a mark across the inner and outer rings and keep an eye on it. Just because the thing has a slight wobble doesn't mean it wasn't installed correctly, or that the bolt has loosened.
If the marks move, then you have a problem.
do you mean make two new timing marks? do i just look to see if they have moved while the motor is off or do i have to use a timing light?
Old Mar 26, 2011 | 05:55 PM
FRCTony's Avatar
FRCTony
Just make a mark across the front covering the inner and outer rings, and the rubber section. As long as the mark stays in line, the outer ring is not moving. Just check it periodically (with the motor off).
Old Mar 26, 2011 | 06:18 PM
zeevette's Avatar
zeevette
I was going to recommend the Powerbond balancer as well. I have a std. size one now, and when I was NA, I had a %25 UD one. Cost me $160 new, and pinning is a great idea. BTW, if you do replace the balancer, (not saying you need to) it's an excellent time to do a cam swap. About %90 of the work is done by taking off the balancer, and you can realize an easy 25-40 RWHP gain by just a cam change. (and valve springs!)
