Harmonic balancer questions
Old Mar 25, 2011 | 12:18 PM
shift's Avatar
shift
Default Harmonic balancer questions
Hello all.
When I bought my car back in January, I noticed the harmonic balancer was wobbling. After joining the forum I discovered this is somewhat common, but should be fixed.
The balancer that is on the car is fairly new, I found paperwork from the previous owner that said it had been replaced within the last 10k miles.
Right now it is wobbling about .050", is this enough to warrant concern?
Also, if I am going to fix it, I would prefer to do it right and use a good pulley, such as an ATI. But, they are around $400. I can get the NAPA part, it is only $100 but I do not want to have to do this again in a year or so.
Any advice is appreciated.
Thanks!
Old Mar 25, 2011 | 12:43 PM
chevy406's Avatar
chevy406
You need to fix it NOW. It will only get worse and can lead to damage on the crankshaft snout, front cover, or even the steering rack.
Get an ARP balancer bolt to go back in it, and make sure it's tightened this time.
Old Mar 25, 2011 | 12:54 PM
Paul 75 L82's Avatar
Paul 75 L82
Sounds like it was just an installation problem, I don't think the stock pulley is a bad design.
Old Mar 25, 2011 | 02:48 PM
corvettebob1's Avatar
corvettebob1
Why would you say that when there are such a high number of failures right here on this forum?
The other issue is when a balancer is replaced it should be pinned to the crank, another poor design!
Old Mar 25, 2011 | 03:29 PM
VET IT B's Avatar
VET IT B
Any wobble is too much. Get it fixed.
Old Mar 25, 2011 | 03:32 PM
vettenuts's Avatar
vettenuts
0.050" is less then the spark plug gap. If you have evidence it was recently replaced, are there problems that lead you to believe it needs replacement again?
Old Mar 25, 2011 | 03:38 PM
shift's Avatar
shift
just want to make sure I avoid any unneeded headaches
Old Mar 25, 2011 | 03:46 PM
shift's Avatar
shift
any recommendations for a replacement pulley and pinning kit? (preferably with part numbers )
Old Mar 25, 2011 | 04:46 PM
bucketlist1957's Avatar
bucketlist1957
Default ATI Balancer
You may want to do a search on ATI Balancers. There is a post or several about that particular brand causing problems.
Old Mar 25, 2011 | 05:00 PM
ipuig's Avatar
ipuig
St. Jude Donor '09
How did you come up with the .050" figure? Unless there is a visible installation problem, I would not recommend replacing a harmonic balancer with only 10,000 miles of use, waste of time and money in my opinion.
Old Mar 25, 2011 | 05:10 PM
lucky131969's Avatar
lucky131969
I'm familiar with the issues with "ASP", but not "ATI". Can you direct me to a thread?
Old Mar 25, 2011 | 05:18 PM
shift's Avatar
shift
rough estimate from a dial gauge
Old Mar 25, 2011 | 07:31 PM
shift's Avatar
shift
Actually according to the paperwork it was replaced 3k miles ago. New pulley, seal, and bolt. I have no idea why it would be wobbling after such a short time, or why it was replaced in the first place.
Old Mar 25, 2011 | 08:47 PM
69SSC5's Avatar
69SSC5
how did you measure how much the balancer was wobbling? just curious so i can measure how much mine is wobbling
Old Mar 25, 2011 | 08:50 PM
vettenuts's Avatar
vettenuts
Not sure where you got this, ATI is the flat out best aftermarket balancer available. ASP has issues if that is what you meant.
That's what I was thinking as well.
Old Mar 25, 2011 | 09:11 PM
shift's Avatar
shift
dial indicator
Old Mar 25, 2011 | 09:27 PM
69SSC5's Avatar
69SSC5
guess i need to get me one of them
To Harmonic balancer questions
Old Mar 25, 2011 | 10:16 PM
bucketlist1957
Default My Bad
I made a mistake. Sorry ATI. I read it quick and was thinking about the ASP problems.
Old Mar 25, 2011 | 10:33 PM
FRCTony's Avatar
FRCTony
Just make a mark across the inner and outer rings and keep an eye on it. Just because the thing has a slight wobble doesn't mean it wasn't installed correctly, or that the bolt has loosened.
If the marks move, then you have a problem.
Old Mar 25, 2011 | 11:07 PM
shift's Avatar
shift
That sounds like a good idea for now, wish I would have done it before I took it for a drive tonight.
thanks
