c6 t56 internals fit on c5 case?
Old Mar 27, 2011 | 02:47 PM
The Highlander's Avatar
The Highlander
Default c6 t56 internals fit on c5 case?
Just wondering if I can put in all the internals of a c6 z06 trans into a c5 case.
Old Mar 27, 2011 | 10:04 PM
LSGUN's Avatar
LSGUN
Check out Rick Kims website its called RKT56.com, send him an email he knows T56s inside and out
Old Mar 27, 2011 | 11:39 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I had my buddy George convert my MN12 to a TRANSZILLA T60/60 6 speed.. You have to use a special face plated front plate.
If you need a conversion, he the man to see!!! :
LOOK AT THIS SET UP ITS THE BEST U CAN BUY IN A T56 MAGNUM
WE BUILD A PERFECT SET UP WITH BELLHOUSING THIS T56 COMES COMPLETE WITH MAGNUM GEAR TRAIN CARBON RINGS 1-4 BLUE PRINT MATCH FITTED GEARS. WE STOCK THEM READY TO GO SHIFTER LOCATION IS 25" FROM ENGINE WE SELL A ALUM OR SFI BELLHOUSING , QUICK RELEASE SLAVE AND REAR 30spl.YOKE FOR THIS TRANS.
TRANS IS RATED GEARS AND THE MAINSHAFT 850FTLBS OF TORQUE
RATIO'S
2.66 1.78 1.30 1.00 .74 .50 OR .80 .62
2.97 2.07 1.43 1.00 .74 .50 OR .80 .62
2.29 1.60 1.21 1.00 .84 .67
TRANS NEW 3495.00 - 3995.00
SFI STEEL 465.00
QUICK RELEASE SLAVE 349.00
30 SPLINE REAR YOKE 169.72
RSG OIL 5QTS 10.55 PER QT, WE MAKE OUR OWN OIL
SINGLE DISC CLUTCH WITH FLYWHEEL 500.00 EST
TWIN DISC WITH FLYWHEEL 1300.00 EST
WE USE RAM CLUTCHES
THANKS GEORGE
RSG RACE DIVISION
HOME OF THE TRANZILLA 6 SPEED
Old Mar 28, 2011 | 12:23 AM
stainless40cal's Avatar
stainless40cal
Simple answer no. t6060 (c6 z06) tranny is very very strong but a built t56 will hold a lot of power as well
The question is what you looking to do with this tranny?
Old May 14, 2011 | 02:52 PM
ChevyEFI's Avatar
ChevyEFI
2006-2007 is a T56 - yes; the 1pc. countershaft and tailhousing go together due to bearing differences.
2008+ is a TR6060 - not without buying additional TR6060 parts.
Old May 15, 2011 | 02:18 PM
ragtopws6's Avatar
ragtopws6
The answer is NO! The 06-07 Z06 T56 have a 1 piece counter shaft with a straight bearing at the end rather than a tapered one and it will not fit. I have experimented with using a spacer around the straight bearing to drop into the tailshaft housing and that has worked. It can be done but not without the special spacer.
To c6 t56 internals fit on c5 case?
