dead battery caused this...
Old Mar 27, 2011 | 06:57 PM
Michael99Vette's Avatar
Michael99Vette
Default dead battery caused this...
My battery went dead and I left it dead for quite awhile. I finally got a new battery and found the key fob quit working and the tire pressure sensors quit working. The key fob was an easy fix but according to my manual it says, " if you are unable to display your tire pressures while the vehicle speed is greater than 15 MPH, you may need to have your sensor ID codes learned by the vehicle. See your Dealer."
I don't have a Dealer I trust. Is there any other way to fix this?
Thank you.
Mike
Old Mar 27, 2011 | 07:08 PM
87SAM's Avatar
87SAM
http://forums.corvetteforum.com/c5-t...-learning.html
Old Mar 27, 2011 | 08:37 PM
Michael99Vette
Thank you for the information. I should be good for now.
Sincerely,
MIke
Old Mar 28, 2011 | 04:19 PM
Michael99Vette
OK, the directions are really clear. The only question I need answered is... what's considered a large magnet (how big does it need to be)?
Old Mar 28, 2011 | 05:08 PM
87SAM's Avatar
87SAM
Some can get it done with a small one and others use one the size of the speaker magnet. I normally use a rectangular magnet about 1 ½ X ¾ X ¼ inch. I have also been successful with one of those mechanics magnet on a stick thingy. I guess it depends on the sensor or the technique.
Old Mar 28, 2011 | 06:23 PM
Michael99Vette
Thank you.
MIke
Old Mar 28, 2011 | 06:29 PM
Bill Dearborn's Avatar
Bill Dearborn
I used to use a 99 cent magnet I got at Radio Shack.
Bill
Old Mar 28, 2011 | 06:40 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
If you don't already have a magnet, I'd suggest the local hardware store that carries "Stanley" items. They make a round magnet that's about 3" in diameter, and works well. It's a couple of dollars....
Old Mar 29, 2011 | 08:23 AM
76 VETTE's Avatar
76 VETTE
Good info!
To dead battery caused this...
