c5 seat problem
Old Mar 28, 2011 | 05:18 AM
Mikejan's Avatar
Mikejan
Default c5 seat problem
Hi. i have c5 and today heard driver seat making clickin noise then as soon as i did seat and turn on the engine the seat goes totally forward .and I couldnt even come out of the car.who can please help me to solve this problem.also inform that the seat looks lock now.
Old Mar 28, 2011 | 09:27 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
While not sitting in the car, see if you can move the seat with the controls, then re-memorize the postions with the memory buttons. Next, check the two connectors and the bottom of the seat to the car interface. Make sure they are clean, tight and good connections and know that most of the seat problems are found right there. Oh, before doing any of this, pull your codes.
Old Mar 29, 2011 | 03:40 AM
Mikejan's Avatar
Mikejan
hi.thanks for respond .but the stupid seat is still in lock position and the switches not working. so i think i should dissassemble the seat and remove it. can some one say if i can reprogram the seat or how should I do that? thanks
Old Mar 29, 2011 | 08:26 AM
dgrant3830's Avatar
dgrant3830
Did you pull your codes yet? Check the fuses. To get the seat out, you'll need to access all four nuts in the seat's four corners. Since your seat is misbehaving, I suggest that you disconnect the battery or electrical connectors to the seat BEFORE sticking your arms under it...just in case it decides to move on its own.
Old Mar 30, 2011 | 03:36 AM
Mikejan's Avatar
Mikejan
thanks for respond, but one more stupid question, how should Ipull the code? and also want to say the seat does not have memory on doorpanel. I took the seat out but I dont know how to fix it the seat switch is not working at all by touching & I check no 3 no 4 fuses those are in working condition.
Old Mar 30, 2011 | 08:19 AM
dgrant3830's Avatar
dgrant3830
Codes are displayed on the DIC and its the most important tool that you have...cool too that it's built in for you. Push and hold the Options button and touch the fuel button 4 or 5 times within 5 seconds. It will automatically scroll through the codes. Be prepared to write them down. Using the Options button again will place it into the manual mode where you can use it to scroll down through the codes or the other buttons to scroll back up. The "Reset" button will clear any code if you select the code, push and hold the reset and it will clear. The E/M button will exit the code display. For the seat, the codes will appear in the SCM are which stands for Seat Control Module.
Lucky or Bill Curlee will have the seat schematics as mine are only for a '99 and they're not always correct. You need to verify power at the seat connectors since you have the seat out. Will venture a guess that your seat switch is having problems as we've heard of them failing before. Do you know how to use and do you have a DVM (Digital Volt Meter)?
Old Mar 30, 2011 | 11:57 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
What year C5 do you you have and are you sure that you dont have MEMORY?
Like Dave stated, the seat multifunction switch frequently fails and causes issues like this. That would be the vey FIRST place that I would look.
Do you know how to use an OHM Meter and read shhematics???
Here is an over view on reading DTCs:
READING YOUR Engine Diagnostic Trouble Codes (DTC)
This procedure should be carried out any time you experience a problem with your C5. Most inexpensive store bought aftermarket code readers will ONLY read power train DTC’s. Reading the DTC’s with the C5 built in code reader will allow you to read ALL the modules in the vehicle.
The Diagnostic Display Mode is entered with the following procedure:
1) Turn on the ignition but don't start the engine.
2) Press the RESET button to turn off any warning messages. (i.e. door open, trunk open ect)
3) Press and hold the OPTIONS button
4) While holding OPTIONS, press FUEL button four times within a 10 -second period.
Initially, the on-board diagnostics go into an Automatic Mode which will cycle through each module and shows diagnostic codes in a pre-set sequence: PCM - TCS - RTD - BCM - IPC - RADIO - HVAC - LDCM - RDCM - SCM - RFA. All codes will be displayed for each module. ( i.e. PCM = 4 codes) If none are present in a given module, you will see No More Codes on the display.
There are two types of diagnostic codes, Current and History designated with a letter suffix, “C” or “H”. A current code indicates a malfunction is present in the module displaying data. A history code indicates a problem existed sometime in the last 40 or 50 ignition cycles. When not accompanied by a current code of the same number, it's potential evidence of a previous problem, now resolved, that was not removed by clearing the codes. More likely it's an indication of an intermittent malfunction.
Intermittent codes are the most challenging of the diagnostics. An intermittent code may have happened once, may have happened more than once but is inconsistent or may be happening on a regular basis but not at the time the codes are displayed. History codes can also be caused by a current malfunction in a system that is not operating at the time codes are displayed. An example is the rear window defogger which doesn't operate until the Body Control Module detects engine rpm. For history codes set by a module that does not operate with the key on and engine off, a special diagnostic tool called a Scan Tester is necessary to properly diagnose the malfunction.
Once the system has displayed all modules, it goes into the manual mode which allows selection of each module using combinations of Driver Information Center buttons. Manual mode can also be entered during the automatic sequence by pressing any button except E/M. Once the display shows Manual Diagnostics, select a module by pressing the OPTIONS button to go forward or the TRIP button to go back. Once a module is selected, a code is displayed, and if more than one are present; press GAGES to go forward or FUEL to go back.
To exit the diagnostic mode at any time, press E/M. If you want to erase codes in a given module, press RESET To reset the codes once in manual mode, press and hold RESET until it displays NO CODES Press OPTIONS to go to the next module. Repeat the steps until you have reset the codes in all the computer modules.
NOTE!! Only reset the codes IF you want to - it is NOT necessary to do this. Clearing a code does not repair a problem. You are simply erasing the evidence of it in the module's memory. If you clear the code/s, and extinguish the Check Engine Light, your emissions status ready will NOT allow you to pass an emissions test until you have completed the required driving cycles. There are a few body module DTC’s that if set will prevent the module from operating properly. Once the DTC is cleared, the module will return to full function. This is not true for power train DTCs.
If you have never read and cleared your codes, there will probably be a lot of old history DTCs. It is recommended that you clear your codes and see if any come back during a driving cycle. Those are the ones that you need to concentrate on diagnosing.
Once you have the codes, the next question is: What to do with the information?
First, consult the factory service manual. Any serious C5 Do-It-Yourself owner should invest in the Corvette Service Manual of the appropriate model year. The Service Manual is really a requirement if you want to understand and work on your C5.
NOTE and a WARNING. You can read the DTCs while the engine is running. I pull mine up all the time while driving.
WARNING. Don’t become distracted while reading DTCs while your driving and cause an accident!!!!! Use common sense and drive safe.
These are some very good C5 Diagnostic Trouble Code (DTC) explanation web sites!!! They also explain how to read the DTCs
Here are some very good sites that explain what DTC mean:
http://www.gearchatter.com/viewtopic11755.php
http://www.obd-codes.com/trouble_cod...d-ii-codes.php
Make sure to include the H or C suffix when you post your DTCs!!
Old Mar 30, 2011 | 03:59 PM
Paul Wood's Avatar
Paul Wood
I agree with Bill Curlee. The OEM seat is poorly designed as your weight is on the outboard edge of the seat when you exit the car and it is vulnerable. The air connections were broken on my seat and had to be replaced. I had the seat built up a bit with stiffer foam and that helped a lot as well. Good luck in diagnosing the problem. The forum is a great source of information and someone will be willing to help you through each step if you only ask.
Old Mar 31, 2011 | 05:55 AM
Mikejan's Avatar
Mikejan
Thank you so much for the detailed responses guys, I appreciate it so much and I will let you know how it goes.
Old Mar 31, 2011 | 09:14 AM
trmracing's Avatar
trmracing
4th Gear
Default C5 Seat Problem
I had multiple problems with both seats in my 99 that I just purchased this past Jan. All of the problems were fixed when I replaced the power seat controls -
To c5 seat problem
