h.u.d. brightness
Old Mar 31, 2011 | 11:14 AM
ClockworkC5's Avatar
ClockworkC5
Default h.u.d. brightness
ive got mine finally all hooked up and it works. is there anyway i can make it brighter? i turned up the brightness all the way, but can barely see during the day. ive heard other people complain about it, but has anyone figured out a way to fix? thanks
Old Mar 31, 2011 | 11:19 AM
87SAM's Avatar
87SAM
It may just be that way if you don't have a HUD windshield.
Old Mar 31, 2011 | 11:50 AM
ClockworkC5
are you pulling my leg, or is there such thing? if so, is there something that i could spray and clean the windshield to make better?
Old Mar 31, 2011 | 12:05 PM
jrose7004's Avatar
jrose7004
I don't have a HUD windshield and it's plenty bright day or night!
Old Mar 31, 2011 | 12:11 PM
TheWildcat's Avatar
TheWildcat
mine to try to move the dimmer switch up and down..John
Old Mar 31, 2011 | 06:50 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Assuming you have the hud controller and the dimmer doesn't do anything, the next question is was this HUD new? There is a light sensor at the top center of the HUD facing forward and it controls the brightness during the day time when the headlamps are off. Did you have a Tech 2 program in the RPO code for the HUD so that the BCM knows its there?
Old Mar 31, 2011 | 11:45 PM
ClockworkC5
used hud unit. i have friends with hp tuners. is there something that should/could be tuned?
Old Apr 2, 2011 | 08:08 AM
dgrant3830's Avatar
dgrant3830
No tuning will help anything with this. So you have the intensity turned up and it's still dim? Is it dim at night? Day vs Night are two different sources of brightness commands.
To h.u.d. brightness
