Seafoam or techtron
Old Apr 1, 2011 | 01:06 PM
cbruer's Avatar
cbruer
Default Seafoam or techtron
Which is better for fuel system cleaning?
Old Apr 1, 2011 | 01:07 PM
oh1vette's Avatar
oh1vette
You'll get opinions for both, but techron worked for me correcting the fuel sensor issue....
Old Apr 1, 2011 | 02:37 PM
edaniel7's Avatar
edaniel7
IMO...Seafoam for intake/upper cylinder...Techron for fuel tank, lines, guage and injectors
Old Apr 1, 2011 | 03:11 PM
trussme's Avatar
trussme
Default Techron for fuel systems
with edaniel7
Old Apr 1, 2011 | 03:30 PM
baxsom's Avatar
baxsom
seafoam is rubbing alcohol, light petroleum and naptha.
techron is SOLVENT NAPHTHA, PETROLEUM, LIGHT AROMATIC C8-C10 -- 68%
Mixture of hydrocarbon solvents including methyl cyclohexane (naptha) [C7],
Toluene (aka methyl benzene [C7]), three isomeric xylenes (dimethyl benzene
[C8]), and ethyl benzene [C8]). These are simply common solvents for
non-aqueous systems.
>TOLUENE
< 0.1%
>XYLENES
< 0.1%
>ETHYL BENZENE
< 0.1%
>POLYETHER AMINE
32%
Polyether amine is a detergent designed for use in non-aqueous systems.
Techron is simply a soap-like material which can solubilize solid organic
crud (technical term)
I would go with techron, more chemicals meant to scrub stuff.
Old Apr 1, 2011 | 03:49 PM
mre1974's Avatar
mre1974
>TOLUENE
< 0.1%
>XYLENES
< 0.1%
>ETHYL BENZENE
< 0.1%
>POLYETHER AMINE
32%
WoW...great post. I didn't know alot of that. I've been using Seafoam in my 2001 VW for over 10 years now for the intake AND fuel systems. Seems to work well but I may have to look into Techron a lil more throughly now. Have to admit...Seafoam in the intake manifold and the smoke show after is ALOT OF FUN.
Old Apr 1, 2011 | 10:52 PM
Stimmel's Avatar
Stimmel
Cruising
I love seafoam its great I have used it on numerous vehicles in all three uses never had a problem and had many great results, But I have never heard anything bad about techron either i just picked up a 99 c5 with 100k on it just dumped a seafoam in it so we will see
Old Apr 2, 2011 | 09:39 AM
87gtNOS's Avatar
87gtNOS
I would drink Seafoam if I could...
It goes in everything with an engine that I own.
Corvette - gets a small can once a month
02 Tahoe - same as Vette
95 Cherokee - same
Bass boat - gets a can with EVERY tank of fuel (25 to 35 gallons of fuel every weekend!)
ZX14 - gets a half can once a month
both snowmobiles get Seafoam everytime they leave the garage!
Old Apr 3, 2011 | 08:43 AM
mtdoragary's Avatar
mtdoragary
From: eustis FL Saved and blessed; what else matter?
>TOLUENE
< 0.1%
>XYLENES
< 0.1%
>ETHYL BENZENE
< 0.1%
>POLYETHER AMINE
32%
The longer Seafoam stays in your tank, the more water it attracys and absorbs. Never use it as a stabilizer, only as a cleaner!
Old Apr 4, 2011 | 12:37 PM
JustCruzin's Avatar
JustCruzin
Both will clean and both will wash all the crud into your injector filter baskets, Take them out and send them in if you want it done right IMO
To Seafoam or techtron
