3 Piece Wheel Advantages?
Old Apr 17, 2002 | 12:35 AM
DsC5's Avatar
DsC5
Default 3 Piece Wheel Advantages?
What is the advantage to a 3 piece wheel, e.g. HRE? It seems to me that a 1 piece would be stronger. Also - is there any real advantage to the high $$ aftermarket wheels besides cosmetic? Don't get me wrong, the HRE's and others are some great looking wheels, but does it really make a difference? :seeya
Old Apr 17, 2002 | 12:58 AM
Nitro-C5's Avatar
Nitro-C5
Moderator
St. Jude 15 Year Donor
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '08-'25
Default Re: 3 Piece Wheel Advantages? (DsC5)
CCW I think can geive you a great advantage. They are lighter, stronger and come with a large variety of sizes over stock rims. They are also much less expensive then "cosmetic" wheels.
Old Apr 17, 2002 | 03:22 AM
UFOVette's Avatar
UFOVette
If you curb your wheel, with three piece wheel, you only have to replace outter section :cheers: Three piece wheels are cheaper to repair.
Curb a one piece wheel you replace whole wheel :mad
Old Apr 17, 2002 | 08:20 AM
speeder75's Avatar
speeder75
Default Re: 3 Piece Wheel Advantages? (UFOVette)
They are not always lighter but most of the time heavier, and i think the only disadvantage of a 3 piece wheel is that it will look smaller than a one piece because of the a small center then around that the bolts then the lip, where in the one piece you have the lip and center only, so you have a bigger gap between the center and the lip which shows that the wheel is bigger.
Old Apr 17, 2002 | 10:01 AM
racewheel's Avatar
0racewheel
Former Vendor
one of the adavantages is the ability to make custom widths and offsetts
Old Apr 17, 2002 | 11:14 AM
Slammed Vette's Avatar
Slammed Vette
Cruise-In II Veteran
Cruise-In III Veteran
Mine are way lighter and I couldn't get a a size that would work with the tires i want to use.
Old Apr 17, 2002 | 03:43 PM
HIGHRPM's Avatar
HIGHRPM
Default Re: 3 Piece Wheel Advantages? (Slammed Vette)
One big advantage of the 3 piece wheel is it allows you to change the rim width without buying a complete new set of wheels. I recently changed my HRE 547's from 11" to 12" in width. The cost was $210 for the wider inner ring. If you bend an outer ring its a $190 relacement cost. Considering that these wheels list for over $1200 each....this is an important point.
Old Apr 17, 2002 | 05:30 PM
C5-VERT's Avatar
C5-VERT
Default Re: 3 Piece Wheel Advantages? (HIGHRPM)
Everyone is correct :yesnod:
Old Apr 17, 2002 | 07:47 PM
MitchAlsup's Avatar
MitchAlsup
One big advantage is that the center section can be forged, while the rims themselves constructed out of lesser materials (Spun, cast, pressed).
Old Apr 17, 2002 | 09:03 PM
WildWolf's Avatar
WildWolf
Slammed Vette-I love the way ur car looks!
To 3 Piece Wheel Advantages?
