Hawk HPS pads question
Old Apr 7, 2011 | 07:37 PM
mcgilles's Avatar
mcgilles
Default Hawk HPS pads question
Hawk HPS pads have metal tabs, or clips attached to one end of 2 out of each set of 2 pads. the clip is in the opposite direction of the pad surface.
last time I had the stock pads off I don't remember seeing anything like that. could be that I just don't remember, its been a while. but what do I do with this clip? does the pad with the clip need to go on the inside or outside face of the rotor?
Old Apr 7, 2011 | 08:02 PM
Bill Dearborn's Avatar
Bill Dearborn
I think you are describing the wear sensors that are also on the OEM pads. The GM FSM states the pad with the sensor should be placed in the inboard pad position with the sensor located in the trailing position. On the front that would be at the top of the caliper and in the rear that would be at the bottom of the caliper.
Bill
Old Apr 7, 2011 | 08:05 PM
mcgilles's Avatar
mcgilles
Bill
Thanks! I started to figure that out when I noticed them on opposite sides. Inside then. Thanks!
To Hawk HPS pads question
