Leaning out after Fast 92?
Started right up no problem idled fine for about a 10 min drive. I come home I unplugged the battery to reset PCM and Then drive to the car to the car wash. Shut car off, wash car, on the way home idle started getting funky go to zero and then to 1k and would repeat this but would not die
so I'm assuming this is my car leaning out after the egt is getting to hot?
the car was tuned a couple years ago @ cartek
thinking of towing it to ecs for another tune ASAP
I'd take my business elsewhere.
BC
my car has
5.3 stage 2.5 heads, thunder racing "Split Pattern" - 224/227 .563/.569 114 LSA, cartek 1/78 headers, RT cats and x-pipe, bansani catback
3.90 and cartek clutch
my car has
When the car is in Closed LOOP, I would say, yea its NOT going to be correct. Your only in open loop at cold start up and when your at a throttle angle and load that causes the PCM to trip into open loop. That not very much in normal daily driving..
Hows your "highway" fuel economy????
If closed loop is locked out,, it wont be very good..
Doesn't sound correct to me unless there more to the story that you or I I'm being told. Did they do an SD Tune??? Like I said,, I'm not a tuner but,,,
gas mileage is general is pretty bad around 15 average goes up to 25 or so on the highway
Give him a call and discuss your issues and goals.
Bill Curlee
