Heads/Cam Install
Old Apr 17, 2002 | 06:46 PM
Andy_A's Avatar
Andy_A
Default Heads/Cam Install
My heads and cam package is being installed in the next couple of days. As part of the package I am using a Cloyes adjustable gear set. I was advised to set the adjustable gear set advanced by 2 degrees. Opinions appreciated.
Old Apr 17, 2002 | 10:21 PM
wstory1's Avatar
wstory1
Default Re: Heads/Cam Install (Andy_A)
I'd go with their recommendation. They should know what they're talking about if you're using a reputable mechanic/tuner. If you don't do it and you're not happy it's your fault. If you do it and you're not happy it's their fault. Most likely 2 degrees won't make enough difference that you'd ever notice it except on a dyno anyway.
Old Apr 17, 2002 | 11:55 PM
Chris@SD's Avatar
Chris@SD
Who is doing the install? How is the cam ground? What is the LSA and ICL of the camshaft. How about the duration also?
What are you looking to do with the car? Will you have an aftermarket rev limiter? Are you looking for the best 1/4 mile time or the best overall street performance?
Throw me some answers to these questions and I can accurately evaluate what you ought to do with the timing gear.
Good Luck,
Old Apr 18, 2002 | 09:12 AM
Andy_A's Avatar
Andy_A
Default Re: Heads/Cam Install (Chris@SpeedDemon)
Chris, thank you for the response. The work is being performed by personal friend/tech at a Chevy dealership. Unfortunateley no "tuners" in my area.
Aftermarket rev limiter set to 6800 and I am looking for best overall "street" performance.
Here are the cam specs:
566 Intake
569 Exhaust
222 @50 Intake
226 @50 Exhaust
114 Lobe
Again, thanks for your help!
Old Apr 18, 2002 | 12:17 PM
Austrian Vette's Avatar
Austrian Vette
I have set mine to 0!!
Hope I did it right!!
Michael
Old Apr 18, 2002 | 07:59 PM
Chris@SD's Avatar
Chris@SD
Do you know how many degrees advance were ground into the cam?(what ICL it is on). That is the last thing we need.
Old Apr 18, 2002 | 10:16 PM
Andy_A's Avatar
Andy_A
Again thanks for the help. Unfortunately I am a "rookie" and not familiar with the term ICL (maybe intertake center line). If that is the case it is a Comp Cam and the paperwork reads "These specs are for cam installed at 114 Intertake Center Line. I hope this is the correct information.
To Heads/Cam Install
