Clunk sound in front end
Old Apr 14, 2011 | 12:17 AM
C5nNC's Avatar
C5nNC
Default Clunk sound in front end
10,000 mile 02 Z06. when suspension loads or you turn sharply I hear a clunk sound. Sounds like something hanging loose and hitting frame or underbody. Have extensively looked everywhere and find nothing loose. Just started this week and progressively getting more frequent. Any suggestions?
Old Apr 14, 2011 | 12:28 AM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
get it up on stands and check shocks or sway bar ends. look and I'm sure you can find it.
Old Apr 14, 2011 | 02:47 AM
SoDiezl350's Avatar
SoDiezl350
At first I thought it was my 3 month old bilsteins. I ruled out my end links because I already have metal end links. Turns out those go bad pretty often as well. Already have a heavy duty set on order from VB&P.
Old Apr 15, 2011 | 08:05 AM
MotleyDrew's Avatar
MotleyDrew
if you have ever had the front cradle out make sure the bolts for the cradle are snug.
Old Apr 15, 2011 | 08:20 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I had a pop from the front end of the car too that would only sound when pulling into a driveway at an angle. I started tighening every bolt/nut I could find and discovered a slightly lose tie-rod end end nut. No more pop.
To Clunk sound in front end
