Anyone ever have a problem with a squeeky roof panel. It has been driving me nuts. Its only on the drives side and when I unlatch and relatch it seems to go away for a bit but then comes back. Any ideas?
If you search this you will find it is a farily common problem. People have tried a wide variety of fixes. The latch can be adjusted and that has fxed it for some people. Lubricating the area helped for some and even using a business card or tape between the area has been used. I have the same problem and will adjusting the latch next as the silicone fix only lasted a few days.
Thanks! I tried the lube and it didnt work. I have temporarily used the business card so I will have to adjust it once it warms up a bit. Thanks for all the replys!
Try to TIGHTEN the attachment hardware on the roof panel to the proper torque specs. Theres an entire adjustment procedure in the service manual for the targa top.
