Drove through deeeeep water, now electrical problems
Old Apr 20, 2011 | 01:40 PM
lucky131969's Avatar
lucky131969
Originally Posted by rebelheart
Perhaps in manufactoring processes,but for the home tech? Personally,I would never do it!
.....and some people would never attempt a brake job on a car, but I'm sure you would not hesitate for a second. It all comes down to....knowing what you're doing.
Old Apr 20, 2011 | 07:33 PM
lionelhutz's Avatar
lionelhutz
Rinsing electronic circuit boards in hot water????? Really??????? Yikes!
Yes, hot tap water and blow dry with an air hose. The soldering process is much hotter than any tap water will be. Besides, the PC boards in a C5 just aren't that fragile.
Old Apr 20, 2011 | 10:10 PM
Jnape's Avatar
Jnape
Electronics don't mind getting wet, just when energized they will have issues. Static discharge will nuke chips/ boards if you aren't careful though.
Old Apr 21, 2011 | 08:59 PM
seoulbrooks's Avatar
seoulbrooks
Not sure what exact codes you are throwing to put you into the "Reduced Power" mode but I can tell you when this happened to me I lost one leg of the throttle control outputs. The water shorted out this signal on the PCM and TCM. The modules maybe sealed but high levels of water will get into the connectors and associated signals. The TCM was replaced strictly as a preventive measure while the PCM had damage to the throttle circuits. The PCM was replaced and the car was back in action. Just my experience with similar deep water conditions. Good luck.....
