Recently installed a set of Ti's bought from a forum member. If they had come on the car I might have never noticed but due to my nature of checking stuff after installing I can see the right side tips angle down about 1/4" relative to the left side tips. The mufflers look perfectly aligned and nothing looks like it was ever hit or bent. I believe the right side just wasn't welded onto the muffler exactly right. Before I forget about it I thought I'd ask if anyone knew of a practical way to correct this. I tend to think the short stubs the tips are attached to wouldn't bend easily.
Reason: spelling
Are you sure you did not buy TI's that were originally cut off, and welded back together? I recall recently, that a forum member had some for sale in the parts section that had been cut off the car.....and could not sell them.........so he was going to have them welded back together.
My 2004 z06, i bought new, has always been a little down on the right side. I have tried to adjust them but i can't get them as close to level as i would like.
I put a set on my car back in 02 and had the same issue. I shimmed the right side down a tad with a rubber pad I made. Now they align perfect.
Where did you place the shim? It seems like maybe you could move the whole muffler + tips easier than just the tips alone (bending them). I don't think these tips were ever cut off. They just weren't installed very well from the factory. I doubt if very many non-car-enthusiast people would notice 1/4" but that doesn't make it "OK".
when i first did mine they were not lined up right as well. ended up having to loosen up the exhaust bolts upstream and spin the mufflers a little. was able to tweak their positioning with everything loose and then tighten it all up. the tips are right on now.
Mine are off just a tad. I got them as close as possible, and they have stayed that way for 6 years. I can tell, but it is very hard for the non Corvette nut world to tell. I always look at the Z06's, and most of them seem to be off a tad, also.
My left side tips were hanging down quite a bit compared to the right side. We ended up drilling out the holes in the flanges with a step bit to get more rotation and that took care of the problem.
Yes, it makes perfect sense that a small change at the flange would be multiplied at the corresponding tip set. And like mcm95403 said, you can enlarge the flange holes a little more if need be. I figured you guys would have a solution and makes me feel dumb not to have thought of it already.
Actually, at first we put the bolts in a drill press and used the edge of a flat file to remove the first 3/8" of threads under the bolt heads. That didn't give enough room so we went ahead and drilled the flange holes out one step.
Another option, which I chose, was to switch to a smaller diameter bolt with washers and a nut. The smaller diameter bolt gives you more rotation without having to drill or file. As long as it's tight, it holds.
You just need to shim the rear rubber hangers. It is the easiest way. My original exhaust was quite misaligned from the factory. This is normal GM manufacturing practices. I had the same problem with my 97 Grand Prix GT. Most people did not notice the misalignment on my C5. But, the perfectionist that I am, it bothered me.
