2000 covertible electrical issues
Old Apr 21, 2011 | 10:48 PM
redrocker68camaro's Avatar
redrocker68camaro
3rd Gear
Default 2000 covertible electrical issues
well first when i hit the lock button on key fob . the horn sounds and lights flash ( like as if the alarm is goiung off) . ALSO WHEN I START THE CAR THE LIGHT FLASH REALLY FAST . if i turn on the parking lights you dont see them flash anylonger. the no2 fuse (approach) keeps blowing . when my lights flash the fog light relay under the hood activates and deactivates as well as power is applied and removed to the approach circuit i also hear another relay clicking maybe somewhere on pass side behind the battery. any ideas as to where to start
Old Apr 23, 2011 | 09:33 PM
FirethornC5's Avatar
FirethornC5
Can you post any codes for us?
Also, pull the passenger toe board and check the condition of the BCM. Water may have entered into the cabin from the cowl due to clogged drain udders.
