Radiator
Old Apr 22, 2011 | 12:22 PM
MR.G.'s Avatar
MR.G.
Default Radiator
I purchased a replacement radiator for my 1998 vert. I have read the posts. I have two questions: 1). Some say you have to jack the car up and pull something out the bottom I believe it is the Radiator shroud. Other write-ups don't mention the fact that it has to come out the bottom. Which is correct? 2). Does the c-5 have the quick connect type like the c-6 that requires some type of special tool? Thanks
Old Apr 22, 2011 | 01:19 PM
dmarkshark's Avatar
dmarkshark
I have a 99 vert so its probably the same. You do need to jack it up or have it on something to get under and loosen all of the lines and electrical connectors. I took mine out through the top with no problems. No special tools needed.
Old Apr 22, 2011 | 02:29 PM
Paul 75 L82's Avatar
Paul 75 L82
To Radiator
